Atoolnut Posted April 13, 2012 Posted April 13, 2012 Still a newbie.....stupid question...the cassette door is stuck closed...not a bad thing as posted here but would like to access the aux jack...any easy fixes ..have tried wd40 spray...pushed the stupid thing every way...can this be accessed behind fairing to trip door loose thanks les
Cougar Posted April 13, 2012 Posted April 13, 2012 A real long time ago that happened to me as well I think I had to put a nylon/plastic type wedge on the right side ? and kind of force it open. then after that it worked right. now It has been removed for my gages. good luck and don't break it ! Jeff you would have to remove the fairing and then remove the radio amp behind the door to even get to that door. If you look under the tech section on how to add gages it will show you picture of how to do this.
Cougar Posted April 13, 2012 Posted April 13, 2012 read some of this as well http://www.venturerider.org/forum/showthread.php?t=26118
clarkrcdc Posted April 13, 2012 Posted April 13, 2012 Press both upper corners of the door at the same time and release at the same time. This worked for me.
