reddevilmedic Posted September 7, 2011 Share #1 Posted September 7, 2011 ok, so without getting into the brand too much, what are the recommendations for front tire size? which vendor? if theres a deal, i may get the rear. so which size rear also? should i change the front bearing with it? not sure if its ever been changed. 32k Link to comment Share on other sites More sharing options...
MiCarl Posted September 7, 2011 Share #2 Posted September 7, 2011 Front 120/90-18 65H Rear 140/90-16 71H Check bearings when you have the wheel off. It's not necessary to replace them if they're good. You can find the service manual in the tech library. Link to comment Share on other sites More sharing options...
Black Owl Posted September 7, 2011 Share #3 Posted September 7, 2011 This shoulf help you http://www.dunlopmotorcycle.com/fitmentguide.asp Link to comment Share on other sites More sharing options...
