bike nut Posted July 25, 2011 Share #1 Posted July 25, 2011 I have a 1st generation.The oil indicator on the dash is always on.My oil level in the sight glass is where it is supposed to be.My question is can I bypass the oil sending unit?I have soldered the display unit. Link to comment Share on other sites More sharing options...
Marcarl Posted July 25, 2011 Share #2 Posted July 25, 2011 Have you checked to make sure that the connectors from the unit are making contact? Link to comment Share on other sites More sharing options...
dingy Posted July 25, 2011 Share #3 Posted July 25, 2011 Are you sure it is the oil light? 2nd down on left side is brake fluid. 3rd one down is oil. The oil level indicator is on very bottom of the motor near the front. A single wire leads to the rear and up the left frame near the air dampener control knob. If this wire is grounded on the wiring cable side it should turn indicator off. Gary Link to comment Share on other sites More sharing options...
KarlS Posted July 25, 2011 Share #4 Posted July 25, 2011 Are you sure it is the oil light? 2nd down on left side is brake fluid. 3rd one down is oil. The oil level indicator is on very bottom of the motor near the front. A single wire leads to the rear and up the left frame near the air dampener control knob. If this wire is grounded on the wiring cable side it should turn indicator off. Gary Light has been coming on from time to time for the last month and all the checking and changing oil has not done a thing. Now you post this to make me look like a fool. Think I'll go check the brake fluid now. Oh by the way, Thanks for the post. Link to comment Share on other sites More sharing options...
Venturous Randy Posted July 25, 2011 Share #5 Posted July 25, 2011 (edited) Light has been coming on from time to time for the last month and all the checking and changing oil has not done a thing. Now you post this to make me look like a fool. Think I'll go check the brake fluid now. Oh by the way, Thanks for the post. Yep, that's what we are here for, to make you look like a foo......, I mean to help you keep your bike running great. Actually, about any question you could ask like this has been encountered by someone else and that's why the question was asked back to you. RandyA Edited July 27, 2011 by Venturous Randy Link to comment Share on other sites More sharing options...
Trader Posted July 25, 2011 Share #6 Posted July 25, 2011 If it makes you feel any better....I had to ask a member where the transmit button was for the CB! Link to comment Share on other sites More sharing options...
Venturous Randy Posted July 25, 2011 Share #7 Posted July 25, 2011 If it makes you feel any better....I had to ask a member where the transmit button was for the CB! There's a transmit button? RandyA Link to comment Share on other sites More sharing options...
KarlS Posted July 26, 2011 Share #8 Posted July 26, 2011 Added some brake fluid and went for a ride and my "oil" light doesn't come on anymore. Who would of thought. Link to comment Share on other sites More sharing options...
dingy Posted July 26, 2011 Share #9 Posted July 26, 2011 We're there for you. Could have saved your life !! Gary Link to comment Share on other sites More sharing options...
Marcarl Posted July 26, 2011 Share #10 Posted July 26, 2011 Added some brake fluid and went for a ride and my "oil" light doesn't come on anymore. Who would of thought. Funny stuff,, that brake fluid. Link to comment Share on other sites More sharing options...
