MongoE9 Posted June 14, 2011 Share #1 Posted June 14, 2011 I am about to mount one of Ponch's built center stands and I see a 6" long 3" diameter black tube with a rubber cap on it with a rubber hose running out the end mounted to the angle bracket where I need to mount the stand. First, what is this part and what does it do? Second Is there a relocation mod for this or is this part not necessary? Before I start taking stuff off I would like to know what I am doing before I mess something up. Thanks for any insight I can get... Mongo Link to comment Share on other sites More sharing options...
Ponch Posted June 14, 2011 Share #2 Posted June 14, 2011 (edited) It sounds like the rear shock to me. It doesn't need to be relocated. edit: I bet it is a California emissions device. I bet you can work around it. Can you snap a pic and post it? Edited June 15, 2011 by Ponch Link to comment Share on other sites More sharing options...
Freebird Posted June 14, 2011 Share #3 Posted June 14, 2011 hmmmm....I wonder if it has something to do with California emissions? Link to comment Share on other sites More sharing options...
FuzzyRSTD Posted June 14, 2011 Share #4 Posted June 14, 2011 I am about to mount one of Ponch's built center stands and I see a 6" long 3" diameter black tube with a rubber cap on it with a rubber hose running out the end mounted to the angle bracket where I need to mount the stand. First, what is this part and what does it do? Second Is there a relocation mod for this or is this part not necessary? Before I start taking stuff off I would like to know what I am doing before I mess something up. Thanks for any insight I can get... Mongo Check these out, I am sure this will help. http://venturerider.org/forum/showthread.php?t=1427 http://www.venturerider.org/forum/showthread.php?t=60689 Fuzzy Link to comment Share on other sites More sharing options...
MongoE9 Posted June 15, 2011 Author Share #5 Posted June 15, 2011 Thanks Fuzzy, Freebird and Ponch. I think it has something to do with Cali emissions as well. I have seen all of the other posts and researched all areas for answers prior to asking. I appreciate your assistance. Mongo Link to comment Share on other sites More sharing options...
