stvmaier Posted October 2, 2010 Share #1 Posted October 2, 2010 Hey folks.... I was wondering... when you wired your bike for the trailer... what did you do with the connector?? Is there a way to mount it to the hitch?? not sure what to do with it. The trailer I bought has a 5-pin round connector...... your thoughts??? Link to comment Share on other sites More sharing options...
bryan52577 Posted October 2, 2010 Share #2 Posted October 2, 2010 I got the same thing "5 pin round". Mine is mounted to bottom of hitch. Not sure I like it there, as the first time I pulled the trailer and un-hooked it,,, well lets say I forgot to un-hook the plug cause I didn't see it, and then I sat in the dark with the wife holding a flash light "giggling" as I re-wired it. Bryan Link to comment Share on other sites More sharing options...
stvmaier Posted October 2, 2010 Author Share #3 Posted October 2, 2010 Bet you only did that ONCE!!!! Does it Bolt to the hitch?? Link to comment Share on other sites More sharing options...
bryan52577 Posted October 2, 2010 Share #4 Posted October 2, 2010 Bet you only did that ONCE!!!! Does it Bolt to the hitch?? YES And yes. Bryan Link to comment Share on other sites More sharing options...
ashley9187 Posted October 3, 2010 Share #5 Posted October 3, 2010 I made a very sturdy plug mount for my bike using 1/8th inch thick :aluminum plate cut to the exact size and shape of my license plate extending about 2 1/2 beyond the width of the plate. I use the round 6 pin plug see photo. It is very sturdy and well up and a way from the road spray zone. and can be painted. I will do mine in black. Link to comment Share on other sites More sharing options...
eusa1 Posted October 3, 2010 Share #6 Posted October 3, 2010 used a flat 5 connector and zipped tied to bottom side of hitch, and when i'm not pulling the trailer, my hitch cover hides the connector. Link to comment Share on other sites More sharing options...
Dano Posted October 3, 2010 Share #7 Posted October 3, 2010 I also use the 5 way flat, there is a flat plug holder which is magnetic and I stick that on the side of my hitch. Link to comment Share on other sites More sharing options...
SilvrT Posted October 3, 2010 Share #8 Posted October 3, 2010 Mine runs on the outside from underneath the seat, down the fender and out to the trailer connector. When in use, I just zap-tie it to the signal light. When not in use, I un-tie it from the signal light, route it back up the fender, underneath the trunk and zap-tie it to the mounting bracket somewhere. I have the wires all taped and covered with that corrugated plastic wire loom cover. Link to comment Share on other sites More sharing options...
Rick Haywood Posted October 3, 2010 Share #9 Posted October 3, 2010 I stuff mine up under the bottom of the fender on top of the hitch. Can't see it and it stays put Link to comment Share on other sites More sharing options...
painterman67 Posted October 3, 2010 Share #10 Posted October 3, 2010 this is were I put mine. Its a first gen but it might give you some ideas. David Link to comment Share on other sites More sharing options...
stvmaier Posted October 3, 2010 Author Share #11 Posted October 3, 2010 thanks for all the great ideas!!!! will have to wait till I get my hitch on and figure out which way to go!!! Link to comment Share on other sites More sharing options...
Evan Posted October 4, 2010 Share #12 Posted October 4, 2010 Steve, you have many good ideas now and I am not suggesting my option is as good as many of these. My option which was how my bike was wired when I bought it is simple and it works surprisingly well for me (now that I have acquired a trailer). My 6 wire connector hangs down about 6 inches between my left saddlebag and my fender. If I want to, I can sort of retract it so it is out of sight. Link to comment Share on other sites More sharing options...
felix Posted January 23, 2011 Share #13 Posted January 23, 2011 Go to a hardware store and get a plastic wire holder it is flat with a ratcheted hoop on it that is sticky on the flat side about 2 inches they come i black and white, I just put the wire with the plug end in and close, cost $1.14 Plus tax sinnce I have a removable under fender receiver I just stuck it to the main hitch frame out of the way and cant see it when the receiver is off:lightbulb: Link to comment Share on other sites More sharing options...
