Rickster Posted July 10, 2010 Posted July 10, 2010 While changeing the oil today I noticed oil around both sides of my front tire rim, any clues as to what it could be. I have never added brake fluid and if a seal went on my forks I don't think it would land on both sides of the front rim? couldn't see where it was coming from I cleaned it off and so far it hasn't returned. My brakes are working in the front as well and the fluid is ok in the sight glass.
Guest tx2sturgis Posted July 11, 2010 Posted July 11, 2010 Sounds like a blown fork seal or two. Watch for oil on the fork sliders just under the tins, or even near the axle. Just to cover all bases, is it possible that oil came from a gutter or other low spot where you might have parked? I know...not likely.
buddy Posted July 11, 2010 Posted July 11, 2010 MY 88 Gold Wing had the same problem oil on side of tire area? problem was fork seals seeping just enough to get on the tire replaced the forks seals and problem fixed....
Rickster Posted July 12, 2010 Author Posted July 12, 2010 Since the day I found it and cleaned it off I have had no problems since, strange but is there a way to check the oil level in your forks. I rode today about 200 miles things seemed Ok
skydoc_17 Posted July 12, 2010 Posted July 12, 2010 Hey Rick, If I remember correctly, didn't you say your bike came off the kick stand and went over recently? If that's the case I have seen where a fork seal will let a small amount of oil out when the bike is tipped. It hides in the dust seal, and during hot days will seep out. It's sorta' a one shot deal as long as the bike doesn't get tipped over again. Should be no harm, no foul, except that fork is going to be a few c.c.'s of fluid short. If you have questions about adding more fluid, PM me. Earl
