Godlover Posted June 3, 2010 #1 Posted June 3, 2010 I removed my front wheel to take it in for a new tire. When I put it back together do I need to put any grease on the axle?
mm482 Posted June 3, 2010 #2 Posted June 3, 2010 Yes, it will make it easier to remove next time. Earl
Godlover Posted June 3, 2010 Author #3 Posted June 3, 2010 mm482 said: Yes, it will make it easier to remove next time. Earl Thanks - I'll do it.
N3FOL Posted June 3, 2010 #4 Posted June 3, 2010 mm482 said: Yes, it will make it easier to remove next time. Earl Will Honda Moly60 be the ok grease?
V7Goose Posted June 3, 2010 #6 Posted June 3, 2010 The axle doesn't really need any grease unless it is dry and rusty. Just make sure it slides freely through the bearings and sleeve in the wheel. If you do what to put something on it, any light grease will be fine. Personally, I only use moly grease where it is specifically called for, and I do not use moly60 for anything at all. Goose
