CMIKE Posted January 29, 2010 Share #1 Posted January 29, 2010 Last night I pulled the faring to replace my XM antenna and move the XM on to a new RAM mount, so I had to adjust the wiring with that. I noticed some bolts missing that hold the top trunk on the bike, on the chrome braces that go down to both sides side of the rear fender... Holy smokes. I checked all the rest of them and all of they were loose. I replaced them with some stainless I had on hand till I can do better. I put locktite on all of them. Over 14000 miles on the bike and just now finding this... I have lost one seat bolt and now these bolts. Heads up to all to go check these bolts on your bike before the riding season gets started. . I am wondering what else I should check? I already got the items listed below Dog bones on the engine Chrome trim on the fender tips Had the mufflers off so they got checked Had the both front and rear wheels so all that got checked (brakes calipers included) Tank as been off so that is good Bags have been of so that has been checked Fairing off several times along with the passing lights Risers installed so that has been touched Checked the bag lid hinges several times and know that is something to check regularly. What else do I need to check for tightness? Link to comment Share on other sites More sharing options...
T.J. Posted January 29, 2010 Share #2 Posted January 29, 2010 Every nut and bolt you can find including inside the trunk and side bag lock and hinges. Link to comment Share on other sites More sharing options...
LilBeaver Posted January 29, 2010 Share #3 Posted January 29, 2010 Shift Lever One thing to do (to keep organized and make sure you don't miss some that the dealer would have put on would be to go through the assmebly instructions and check everything that the dealer would/should have touched... Or just start at the front (or wherever) and work your way all the way around the bike... Link to comment Share on other sites More sharing options...
BuddyRich Posted January 29, 2010 Share #4 Posted January 29, 2010 Use Loctite or you'll be losing more. Link to comment Share on other sites More sharing options...
