v max = 1st gen ?
Hi,
no the upper Yoke from a Vmax doesn't fit on a 1Gen.
But, maybe, the Handlebar Clamp would fit.
You can measure the Distance between the two Bolts on the lower Side of the upper Yoke.
If my Memory serves my right, this Distance is 100mm on a Vmax, middle to middle. The Bolts are M10x1,25 Thread and some 40 mm long.
I thought at first the Handlebar on 1Gen where mounted to the Forklegs, but they are not. They are in Fact mounted to Brace which fits in two Borings in the Yoke, similair to most of the naked Bikes all over all Manufactures. On the 1Gen's there are also some rubber Parts involved. But basically, those two Borings in the 1Gen Yoke might fit to the Vmax Handlebar Clamp Size.
Hi again,
hey, thanks for the DQ Offer, but be assured, my Brain saves such Offers in the loooooooooooooong Term Storage ... :D :D :D :D :D
I will measure the 100mm on Monday, i have two of these in my Garage/Workshop.
Even if this Clamp won't work, your can get some of these from another Bike. Only Problem is, most of them would have no 'set Back' like the Vmax Clamp has.
Ok Thomm, My main purpose for changing the bars was I got bad tendenitus in my elbows from the original handlebars. I like my bars more foward. This is what I did I'm not saying its right and everyone should do it, but its what I did.
!. Removed old handlebars from the triple tree.
2. Loosened the Ignition switch.
3. Removed the whats called the lower handlebar holder.
4. Pulled out lower handle bar holder
5. Now your left with the triple tree and the 2 holes for mounting the bars.
I used some risers I got for free from a mechanic friend I believe they
were off of a Yamaha Roadstar dont quote me on that. Now the
problem I had was the risers were slightly thicker then the mounting
holes in the triple tree. So I had do drill the holes out slightly of course
I couldnt find a metric drill bit so I used a 9/16 bit slightly bigger then
14mm and drilled the holes out
6. Now using this bit it was slightly bigger and provided to much side to
movement inside the triple tree so I used an aluminum can cut and then
rolled up and inserted into the triple tree to use as a shim to tighten up
clearances inside Pic #4 and 5
7. Now I could put the risers in and tighten them down.
8. I mounted the Kawasaki Voyager adjustable bars to the risers.
Voyager bars are 1" on the bottom part but are 7/8" on the
top part the adjustable part.
Now the problem is clearances
is the battery cover. The bars
could hit the battery cover so if you do something like this you may
have to try a few combinations of risers and handlebars. The bars
also will hit the windshield and or your mirrors if they are mounted
to far foward.
You can now play with lean angle since you have
normal bars but remember the clearance with the battery cover.
9. Voyager bars themselves present problems. For me the actual handle
bar part was to long to mount the Venture controls this would make
the bars to wide for me and not give me the clearance from the
windshield and mirrors. So I found a spot were I thought it was
comfortable using the Venture Controls next to the Voyager bars
I then cut the Voyager bars down
and slid on the Venture
controls. Next problem with Voyager bars since they are adjustable
they have a big round interlocking point of attachment.
this makes the Master cylinders jut out from the bars since its not flat
like a normal bar would be. This is not ideal for me since you dont have
full contact of the Master cylinders and levers but I tightened it down
and seems to work out fine. Now with this setup I could use the
normal length Venture throttle cables which was good.
10. Now the bars are attached I still want to use the cruise control
but with this setup I cant mount it like it was so I had to cut the
top part off were the ignition would be. Now the problem of
mounting it. I tried Velcro didnt work so I drilled two hole in whats
left of the top part or the cruise unit and attached it with black
cable ties to the handle bars
The cruise unit functions fine.
Now this is not my ideal setup but it works. If I were to do it again (I was in a hurry to ride this summer) I dont need adjustable bars. In reality I will never adjust them I just need one that will work for me and thats a more foward bar but on these bikes your are somewhat limited due the clearances of the battery cover, the windshield and mirrors cable lengths and brake line lengths unless you dont mind modifying things. I delinked my brakes and put in new SS brake and clutch lines of the lengths I needed. I also would probably find risers that would slide right in to the triple tree. So far this setup has been good to me with about 4000 miles on it my elbows are fine and have not had the tedenitus problems. :stirthepot:
Edited by Freebird
I think the lower handle bar holder is 12mm if I remember right. I dont know if they make risers with 12mm posts or not. It's gonna take some fanagling. They also have bent risers that bring the bars back to you more but then you might have to worry about battery cover clearance unless they get the bar up high enough to go over the cover.
Thom I gonna have to do some measuring off of my bike. Peliminary measuring its looks like it might work but alot depends on the bars also. My risers are 2 1/2" high to the center of the bars. It's gonna take me awhile to do this unfortunately I have wedding to go to now. I'll get back to you on this.
I think I sprayed some penetrating oil in if I remember right and used a screw driver to peel it up a bit and twist it. You may need longer cables and brake/clutch lines with that set up if your keep ing those bars stock. Feel free to call me if you have questions.
i did it , your rite jimbob it aint no fun , the nut that holds the stock rizer on was seized , i had to pull the head , glad i did the tube clamps where lose , had to drill out the holes to a 1/2 in. because of the rizers i used , i cut the wish bone clap ,it was about 1/2 in. to narrow ,i was goin to cut both sides and grind them down to look good but i just had to leave it in , besides the cruise central will cover it up . i had to cut the bar tips 2 1/2 in to make the controls fit , the spead is still very nice . i road it around the parking lot it works great , tomorrow i'll cut and mount the c.c rite like jimbob did and take it for a long ride ,its raining now , i got to figger out how to move the key sw. up and mount the cup holder
