davelusk Posted September 23, 2007 #1 Posted September 23, 2007 I'm looking for suggestions or solutions for increasing rider cooling behind the lower fairings on my 05 Midnight Venture. I believe the lower fairing causes some back draft of hot air across my chins after passing through the radiator. Has anyone found a solution for this comfort issue? I've seen a few modifications to Goldwings for rider comfort such as the addition of attached air deflectors on the outside edge of the fairing to direct airflow into the area immediately behind the lower fairing to break up this "hot air backflow". Any suggestions?
Gary N. Posted September 23, 2007 #2 Posted September 23, 2007 http://www.yamahasportsplaza.com/pages/catalogs/detail/26/207/407/3664/1/0/0/1/4/90/69/336/tinted-lower-wind-vents.aspx
Johnh Posted September 23, 2007 #3 Posted September 23, 2007 Yamaha makes air foils that mont to the engine guards. or you can add highway pegs to them
Eugene Posted September 23, 2007 #4 Posted September 23, 2007 Gary N. said: http://www.yamahasportsplaza.com/pages/catalogs/detail/26/207/407/3664/1/0/0/1/4/90/69/336/tinted-lower-wind-vents.aspx My first accesory - wouldn't ride without these in the heat!!!! Cheers Eugene
KiteSquid Posted September 24, 2007 #5 Posted September 24, 2007 in hot weather, I removed the clear plastic deflectors that are on the bottom of the upper fairing. You have to remove the cover to get at the 3 screws each. Also, note that the 3 screws are NOT the same size, so I reinstalled the screws, so I would not loose them or get them in the wrong order when I wanted to re-install the deflectors. A PITA, but it works for me. I wish that the deflectors were easily removable, but then somebody would probably take them.....
TheKid Posted September 24, 2007 #6 Posted September 24, 2007 KiteSquid said: in hot weather, I removed the clear plastic deflectors that are on the bottom of the upper fairing. You have to remove the cover to get at the 3 screws each. Also, note that the 3 screws are NOT the same size, so I reinstalled the screws, so I would not loose them or get them in the wrong order when I wanted to re-install the deflectors. A PITA, but it works for me. I wish that the deflectors were easily removable, but then somebody would probably take them..... I agree it would be a PITA. I was looking at a few HD Ultras and their lowers on the fairing are hinged. That is def what Yamaha should have done. I have been looking at how we could make ours hinged to direct the airflow better. Also wish that the lower fairings could be removed for summer riding like the HD Ultras.
