ToolmanRR Posted July 22, 2009 Posted July 22, 2009 I have a 2006 Royal Star Venture. Are there directions anywhere on VentureRider.org on how to do things like locate the oil drain plug, change the oil filter (tools to use), change the rear differential oil, location of the most common lube points, what viscosity of oil to use in the engine and what viscosity to use in the rear differential, how to get to and change the spark plugs (along with the spark plug gap), and anything else to do in a 8000 mile servicing. A service manual or a PDF file of a service manual would be handy, eh? Thanks, ToolmanRR ( ToolmanRR at Yahoo dot c o m )
RedRider Posted July 22, 2009 Posted July 22, 2009 Both the owners manual and the service manual can be downloaded off this site. All your answers are in there. If you need some specific help on something, give a holler and we will be glad to chime in. [ame=http://www.venturerider.org/forum/showthread.php?t=1828]Download the Owners and Service Manuals - VentureRider.Org[/ame] RR
RandyR Posted July 23, 2009 Posted July 23, 2009 Most of what you said you would like to see is already here in this Tech Talk section. Just look around or use the Search tab
