Guest timshosvt Posted September 4, 2007 Share #1 Posted September 4, 2007 Spare harness has oxidized connectors. I'd rather avoid another fire. What's the best contact cleaner to use on oxidized connectors? Thanks in advance, Tim Link to comment Share on other sites More sharing options...
muffinman Posted September 4, 2007 Share #2 Posted September 4, 2007 CRC makes a good contact cleaner I know Napa has it around here dont forget the Dielectric grease when you put it back together Jeff Link to comment Share on other sites More sharing options...
Guest timshosvt Posted September 4, 2007 Share #3 Posted September 4, 2007 Thanks Jeff, I have some CRC contact cleaner and it didn't do much for the oxidation on the connectors. I think I remember GeorgeS saying something about CRC 26 being the best and I know mine isn't CRC 26. Any ideas as to how to scrub em good? Tim CRC makes a good contact cleaner I know Napa has it around here dont forget the Dielectric grease when you put it back together Jeff Link to comment Share on other sites More sharing options...
Thom Posted September 4, 2007 Share #4 Posted September 4, 2007 lowes has contact cleaner called lecto cleaner , be very careful with it , it will ruin paint , spray some on than wait 30 sec. for a presoak than spray alot more on to clean Link to comment Share on other sites More sharing options...
GeorgeS Posted September 4, 2007 Share #5 Posted September 4, 2007 With a spare harness, I would start with WD-40, as it is a Degresser, spray all the plugs, let soak a couple hours, blow out with compressed air. Then use the crc 2-26, and blow out with compressed air, and If really bad, you might have to do some hand work with small tools and light abbrassive of some type Then check thru every wire at each plug with ohm meter, for a Zero ohm, dead short reading, Link to comment Share on other sites More sharing options...
Guest timshosvt Posted September 5, 2007 Share #6 Posted September 5, 2007 I have a meter, but don't know how to use it. I checked a few items that took some heat when my bike caught on fire, such as the emergency stop switch and the only relay that survived (visually). Both were crispy and not functioning per the manual. My clutch switch made it, but has no insulation. I can't remember the resistance reading. How would I check each connector? Thanks in advance, Tim With a spare harness, I would start with WD-40, as it is a Degresser, spray all the plugs, let soak a couple hours, blow out with compressed air. Then use the crc 2-26, and blow out with compressed air, and If really bad, you might have to do some hand work with small tools and light abbrassive of some type Then check thru every wire at each plug with ohm meter, for a Zero ohm, dead short reading, Link to comment Share on other sites More sharing options...
bongobobny Posted September 5, 2007 Share #7 Posted September 5, 2007 Baking soda made into a paste and applied with a toothbrush also works pretty good... Link to comment Share on other sites More sharing options...
Guest Popeye Posted September 7, 2007 Share #8 Posted September 7, 2007 I only use sulphuric acid to neutralize the rust, after manually removing as much oxidation as possible 'mechanically' with a Dremmel-type tool. Then rinse with water, dry with WD-40 [the fish oil & silicone in it displaces water]. Put together with dielectric grease, for waterproofing, & it should last forever. Link to comment Share on other sites More sharing options...
