Spyder Posted August 22, 2007 Posted August 22, 2007 I ordered a headlight modulator and brake flasher from http://www.comagination.com/modYamaha.htm today. The flasher is the "Brake Flasher (IBF4) with about 4 FLASHES/3 seconds and then stays steady ON until brake is released". I'm trying to decide which lights I want to hook it up to. I have an LED light bar under my trunk and I also have a tail light converter for my cooler rack or for towing a trailer. SO... I was thinking that I would only have the LED lights flash on the bike. I'm also thinking that I should have the trailer brake lights flash even though they are combined with the turnsignals. Does anyone have the combined Stop/Turn Signals and have them set up to flash? Thanks
MrRadi8 Posted August 22, 2007 Posted August 22, 2007 I ordered a headlight modulator and brake flasher from http://www.comagination.com/modYamaha.htm today. The flasher is the "Brake Flasher (IBF4) with about 4 FLASHES/3 seconds and then stays steady ON until brake is released". I'm trying to decide which lights I want to hook it up to. I have an LED light bar under my trunk and I also have a tail light converter for my cooler rack or for towing a trailer. SO... I was thinking that I would only have the LED lights flash on the bike. I'm also thinking that I should have the trailer brake lights flash even though they are combined with the turnsignals. Does anyone have the combined Stop/Turn Signals and have them set up to flash? Thanks I have the LED tail and the run/stop/turn Dynamic Clusters. I split the main brake lead under the seat and they all blink. Personally I like it. If I had the trunk wing I'd have it blink as well. I don't see any value added with a light staying solid. Other opinions may vary.
muffinman Posted August 24, 2007 Posted August 24, 2007 You need to check your state laws in N.C. it is illegal for trailer lights to blink and Ga is as well so before you hook it up ask a state trooper of the law to keep from getting a citation. Jeff
Spyder Posted August 27, 2007 Author Posted August 27, 2007 I hooked it up Saturday morining and made all the brake lights flash. I plan on going to RI next week to pick up a trailer. I'll check on the laws first.Thanks for the advice! Spyder
