r_squared432 Posted July 9, 2007 #1 Posted July 9, 2007 A Newbie to this site with a recent purchase of a 87 Venture Royale with only 55K kilometres (32K miles) on the clock and in fine shape. On a ride yesterday, my headsphone/speaker switch failed with it in the speaker position. I did some disassembly last night and got to the point where I found the small micro-switch soldered into the audio control board. The switch has movement but the internal connections seem to be gone since the LED light indicating the position does not illuminate either. Does anyone have experience with replacing these switches? Can it be done or am I looking at trying to replace the whole audio control module? Alternatively, maybe the switch is fine and the problem is a frayed wire/loose connection elsewhere . Anyone had thiis problem before? Thanks Ron
calperin Posted July 9, 2007 #2 Posted July 9, 2007 What is the switch that you are talking about? where is located? I finished replacing the full audio installation, and I didn't see any switch like that. Regards,
rhncue Posted July 9, 2007 #3 Posted July 9, 2007 r_squared432 said: A Newbie to this site with a recent purchase of a 87 Venture Royale with only 55K kilometres (32K miles) on the clock and in fine shape. On a ride yesterday, my headsphone/speaker switch failed with it in the speaker position. I did some disassembly last night and got to the point where I found the small micro-switch soldered into the audio control board. The switch has movement but the internal connections seem to be gone since the LED light indicating the position does not illuminate either. Does anyone have experience with replacing these switches? Can it be done or am I looking at trying to replace the whole audio control module? Alternatively, maybe the switch is fine and the problem is a frayed wire/loose connection elsewhere . Anyone had thiis problem before? Thanks Ron Yes, I have. The switch can be replaced but you must find a supplier. Radio Shack used to carry them but quit. If I remember correctly they are a 6X6X4.3 mm tact switch. Dick
bongobobny Posted July 9, 2007 #4 Posted July 9, 2007 Just had to replace a bunch of similar P.C. mount switches on the tuner control module due to weathering, I assumed. I used some switches from a display panel for an old CD player but the push part was much longer so I cut them down and filled in the hollow center with some ABS plastic weld. I agree, Radio Shack USED to carry the right ones, but no more. You may try some commercial electronics supply companies like Allied, etc. If you find a solid source, let me know as you never know when one of those switches will fail...
tfair Posted July 9, 2007 #5 Posted July 9, 2007 I have recently been dealing with my own radio nightmare....and I just happen to have an extra volume control panel which has this button on it. The auto volume adjustment (to increase sound as your bike makes more noise) is not working on the unit so it may be a good candidate for dissection. PM me if you think you would like to give it a shot.
Wizard765 Posted July 10, 2007 #6 Posted July 10, 2007 I have / had a similar problem with my radio. The MEM button didn't work so I couldn't get the side buttons to remember stations. Anyhow I took it apart and liberally sprayed electronic contact cleaner into the micro switches and moved them a bunch of times while the cleaner was still wet. Put it back together and all the buttons work fine now.
calperin Posted July 11, 2007 #7 Posted July 11, 2007 Are you guys talking about the intercomm button on the Radio controller? The one that is close to the intercomm volume?
rhncue Posted July 11, 2007 #8 Posted July 11, 2007 calperin said: Are you guys talking about the intercomm button on the Radio controller? The one that is close to the intercomm volume? Yes. Dick
