jb1016 Posted December 12, 2008 Share #1 Posted December 12, 2008 Anybody have this ,my fuel pump used to click when I turned on key. Now it doesnt or maybe clicks 1 or 2 times. Cleaned all connections battery is fully charged and bike starts instantly and runs PERFECT. I`m wondering if there is going to be a problem down the line?? no hesitation and will run all day at 70 -80 mph with power to spare. when bike is idling can feel pulses when I hold hand on pump. any input greatly appreciated JB. Just changed stator last week its putting out 14 volts at 3000 rpm. thanks to all that gave advice on that problem JB Link to comment Share on other sites More sharing options...
Squeeze Posted December 12, 2008 Share #2 Posted December 12, 2008 There is no Problem, the Pump is activated by a Pressure Switch inside the Pump. It pumps until the Pressure is built up and stops by then until you let the Motor run. There is also a Safety Part in the Fuel Pump Relay which prevents the draining of the Tank. When you switch the Key the Pump only operates for 5 Seconds or the Pressure is build up. When there is a RpM Signal on the Ingintion Coil the Relay goes back to normal Operation. Link to comment Share on other sites More sharing options...
Yammer Dan Posted December 12, 2008 Share #3 Posted December 12, 2008 Squeeze has it. If system is working right you won't hear a lot of clicks. Link to comment Share on other sites More sharing options...
Chicoman Posted December 12, 2008 Share #4 Posted December 12, 2008 Good to know this stuff. Thanks for the information. Link to comment Share on other sites More sharing options...
MikeM8560 Posted December 12, 2008 Share #5 Posted December 12, 2008 if my bike has set a few days or so i usually get a number of clicks I didnt think it was a problem:confused24: Link to comment Share on other sites More sharing options...
jb1016 Posted December 12, 2008 Author Share #6 Posted December 12, 2008 Well that sounds good to me,like I said I`m not having a problem with the bike running but until a week ago it always clicked about 5 times when i turned key on . Even if I turned bike off then on again I`d get 5 more clicks.I`ve had the bike since feb 08 and that was normal procedure. Thanks to all for input JB Link to comment Share on other sites More sharing options...
Pam Posted May 15, 2009 Share #7 Posted May 15, 2009 I have an 83 VR. even with a fuel line off I would only get a couple of clickes when I turned the key. If I by pass everthing and go direct the pump runs great. I tracked the fuel pump relay down and it failed the test as per the shop manual. A buddy has one in the mail for me. Hopefully that will fix my problem. frank Link to comment Share on other sites More sharing options...
