eagleeye Posted October 5, 2008 Posted October 5, 2008 Hey Lowell, Did you take if off or are you going to keep running it? Steve
OutKast Posted October 5, 2008 Posted October 5, 2008 Nice. I assume your still riding it? If you have already taken it off the rim, would you measure the inside diameter of the tire? I would like to compare to the inside diameter of my used motorcycle tire, and new tires. Thanks!!
wild hair 39 Posted October 6, 2008 Author Posted October 6, 2008 had a oil seal leaking,final drive,BF GOODRICH 155-80-15,will put it back on the bike,while it's off will put new wheel bearring in also-
BuddyRich Posted October 6, 2008 Posted October 6, 2008 What are you saying here, This is your 2 cents worth 3 times ...:rotf:
Phaedrus Posted October 6, 2008 Posted October 6, 2008 What did you do to get those coins stuck in that tire, run over a meter maid? There is a very dark side to you CT runners!
wild hair 39 Posted October 9, 2008 Author Posted October 9, 2008 2 cants,is about all i have,after the gov,starting bailing us out
