whats the correct idle for an 1984 1200?
I usually keep my idle around 700 rpm's even though everyone says that is too low. You will probably need a carb sync also.
RandyA
You just like the way it sounds at that speed don't you....:stickpoke:
I like the idle sound a bit lower too, it has a nicer rumble
Brian
The idle adjuster is hard to see and reach. It is located between the #1 and #2 carbs. It is horizontally oriented. It is about the size of a dime with raised bumps around the edge. Turning it clockwise increases idle speed (looking at it from underneath).
The adjuster gets hot when the engine is at operating temperature. I use a flat-bladed screw driver to make changes when on the road.
