gibvel Posted April 12, 2011 Posted April 12, 2011 What would be the proper relay to wire the passing lamps? I'm assuming that something like this could be purchased from the local auto parts store.
Steve S Posted April 12, 2011 Posted April 12, 2011 I used a 30 amp LIGHT (continuous duty) relay. This is heavier than you really need, but the price is the same as a 20 amp. I believe in going with heavy amp circuits when possible. My auto parts store had a plug to put on the relay to make the wiring a little easier..
gibvel Posted April 12, 2011 Author Posted April 12, 2011 Thanks Steve. I like to err on the side of caution as well. What, exactly, was the plug you're referring to? I'm assuming it in the same section as the relay.
scooter45 Posted April 12, 2011 Posted April 12, 2011 Off of the relay post #86 i think what wire do you do you tap to have lights on all the time?
gibvel Posted April 12, 2011 Author Posted April 12, 2011 Don't know if these two posts can help but I found these in my searches: http://www.venturerider.org/forum/showthread.php?t=525 http://www.venturerider.org/forum/showthread.php?t=43898 The second is the Yamaha installation documents for the passing lamps. At the bottom it tells you how to hook it up so that the lights work as on all the time, with the brights and with the lows only
