I'm trying to stop a slow oil drip that appears to be coming from the left side of the crank/trans case. So I'm going to replace the clutch shaft oils seal (93109-08061-00), and the shift shaft oil seal (93102-12106-00, (SD 12-22-5 HS)). I was also gonna shim any loose or worn areas while I was in there. Is there anything else I should be looking at down there that may be causing the drip? I don't want to be having to crack open things any more than I have to.
Thanks, Bill
While you're in there replace the O-ring on the neutral sensor. That's probably were you're leaking anyway.... Dingy has pics of the '84 style neutral switch.
There are some pictures of neutral switch in the PDF file that is attached to the post linked below.
Shows its location and how to get to it.
http://www.venturerider.org/forum/showthread.php?t=40639
Gary
