I was told that when changing oil & filter on 89vr you should only refill w/4quarts, I have always refilled w/5 quarts, do anyone know whats best. thanks.
I believe 4 quarts... what I do is put 3.5 quarts in and then run it until good and warm.... then shut off and let it sit for about 1/2 hr... then check the sight glass and top up to no more than 1/2 way.
Having said that tho, we use Litres up here and that's probably a tad less than a US quart.
4 Quarts is over filled.
5 Quarts is way to much.
The service manual lists the oil capacity with filter change as, 3.5 L (3.1 Imp qt, 3.7 US qt).
My '88 takes a little less than 4 quarts to get it to the center of the sight glass.
Edited by Flyinfool
Fat Fingers 3.5L was 3.8L
The service manual lists the oil capacity with filter change as, 3.8 L (3.1 Imp qt, 3.7 US qt).
DITTO
Not sure where you're getting your conversion from but according to my calculations...
3.8 litres = 4.05 US quarts = 3.34 Imp quarts
I did not do any conversions, those capacities are quoted directly from the service manual except for my fat fingers.
It should be 3.5 L not 3.8 L which makes all of the numbers agree mathematically.
The numbers are on page 2-17 of the service manual.
I do agree with your math though.
ahhhh... it's the "finger's fault" excuse again.... :rotf: :sign just kidding:
well, 3.5 Litres would convert properly to those numbers. ya had me goin there tho LOL
It should be 3.5 L not 3.8 L .
Fat Fingers :think:
The 8 is 3 buttons away from 5 :rotf:
Brad
  BradT said:
Fat Fingers :think:
Brad
Actually the 8 is directly above the 5... on the number pad. As an accountant the first thing you look for when a string of numbers don't foot is a digit keyed in that is off by 3.
man, ya lern sumpin new every day... I use the numeric keypad often and have taught keyboarding a few times .... never clued into the "3" difference between the keys that are above/below each other. Cool!
