ecbaatz Posted November 2, 2019 Share #1 Posted November 2, 2019 When I picked up my bike yesterday, the gear indicator was working but both times today when I took it out it did not work. Also when I tried to set the cruise control it would turn on, but I could not set the cruise. I don’t know if the two are related. I did see there is a fuse for the cruise control, but since it turns on I don’t think it is the fuse. Still searching the manual but if anyone has some suggestions, they would be welcome. Thanks, Eric 1 Link to comment Share on other sites More sharing options...
Du-Rron Posted November 2, 2019 Share #2 Posted November 2, 2019 When I picked up my bike yesterday, the gear indicator was working but both times today when I took it out it did not work. As in just bought a brand new bike and the thing doesnt work? Also when I tried to set the cruise control it would turn on, but I could not set the cruise. I don’t know if the two are related. I did see there is a fuse for the cruise control, but since it turns on I don’t think it is the fuse. Still searching the manual but if anyone has some suggestions, they would be welcome. Thanks, I'm lost on the 18's but I would give a call to the dealer. Probably a wire unplugged somewhere. Link to comment Share on other sites More sharing options...
ecbaatz Posted November 3, 2019 Author Share #3 Posted November 3, 2019 As in just bought a brand new bike and the thing doesnt work? I'm lost on the 18's but I would give a call to the dealer. Probably a wire unplugged somewhere. Yes, from the dealer, had 34 miles on it. Indicator worked when I was driving it around the parking lot. Link to comment Share on other sites More sharing options...
ecbaatz Posted November 3, 2019 Author Share #4 Posted November 3, 2019 (edited) I did some checking on the clutch lever and found a push button switch to be out of alignment. (see pic 1) I put it back into position and it now works. (see pic 2). I have both the gear indication and the cruise control working. Thanks for all the advice, it helped steer me in the right direction. Edited November 3, 2019 by ecbaatz Link to comment Share on other sites More sharing options...
sldunker Posted November 4, 2019 Share #5 Posted November 4, 2019 Good job Link to comment Share on other sites More sharing options...
Du-Rron Posted November 4, 2019 Share #6 Posted November 4, 2019 https://www.venturerider.org/forum/attachment.php?attachmentid=117959 I did some checking on the clutch lever and found a push button switch to be out of alignment. (see pic 1) I put it back into position and it now works. (see pic 2). I have both the gear indication and the cruise control working. Thanks for all the advice, it helped steer me in the right direction. This should be made into a "Sticky" in the -Star Venture and Eluder Technical Library ('18 - Present) - READ ONLY- Link to comment Share on other sites More sharing options...
captdrac Posted November 4, 2019 Share #7 Posted November 4, 2019 I'm glad your problem was an easy fix. I had the same problem, but it was a defective front brake lever switch. Not only was the cruise control not working, the rear brake light remained on. I took it to Mukwonago Yamaha ( I have to give Rick props for knowing the most up to date issues on the 2018 Venture) & they said Yamaha knew of the problem. The part was back ordered, but Rick expedited the part and had me riding safely in two weeks. Link to comment Share on other sites More sharing options...
