Guest Raindance1 Posted August 10, 2008 Posted August 10, 2008 We have 2 first gen ventures in garage, and am wanting to swap some parts from 87 to 84.....87 has drive line problem and 84 is going strong, although no second gear. Yamaha site parts listing show part number for frame of '84 to be 41R-21110-00-33 '87 to be 1NL-21110-00-33 question is....will passenger floorboards from 87 fit 84......and will 87 trunk and saddlebags fit 84,,,,,,or will I just hafta start swapping to see what don't fit????
rhncue Posted August 10, 2008 Posted August 10, 2008 We have 2 first gen ventures in garage, and am wanting to swap some parts from 87 to 84.....87 has drive line problem and 84 is going strong, although no second gear. Yamaha site parts listing show part number for frame of '84 to be 41R-21110-00-33 '87 to be 1NL-21110-00-33 question is....will passenger floorboards from 87 fit 84......and will 87 trunk and saddlebags fit 84,,,,,,or will I just hafta start swapping to see what don't fit???? Sorry. The floor boards nor the touring trunk are interchangeable between the two models. You could change the touring pack but to do so the entire rear sub-frame, with the corresponding saddlebags, lights, hand holds and such, must be changed from one bike to the other. Dick
Dano Posted August 10, 2008 Posted August 10, 2008 Sorry. The floor boards nor the touring trunk are interchangeable between the two models. You could change the touring pack but to do so the entire rear sub-frame, with the corresponding saddlebags, lights, hand holds and such, must be changed from one bike to the other. Dick Sub-frame really not that hard to do- a good Sunday afternoon and evening should do the trick. Get that 2nd gear fixed, too. Good winter project to do both things. Dan
