Great White Posted August 13, 2015 #51 Posted August 13, 2015 Condor said: I just had a thought... I know..I know.. about putting together a list of features, or subtle differences, between all years of the 1stGens. Maybe a good idea...maybe not, but outside of colors which are listed in Venture History it might be fun to put together something. So I'll start, chime in if you can think of anything that first appeared in that year and I'll add it to the list. If I don't get any response I'll figure it was a bad idea and pick up my marbles and go away.... 1983 1. TCI is unique 2. vacuum advance comes off carb. 3. Dash is unique 4. Front brake and Gear shifter are adjustable 5. Hydralic anti-dive 1984 1. TCI changed 2. vacuum advance comes off manafold. 3. Choke set rotates in front of LH Grip 4. Cruise Control 5. Dimmer knob, gear position, stop watch added to Dash 6. 1985 1. Larger removable trunk.. unique 2. V-Max tranny after #1417 3 Choke set back to slider 1986 1. 1300 engine 2. Larger saddle bags 3. Larger trunk 4. Choke setting back to slider under horn button 5. larger 4 piston calipers and rotors 6. Wider passenger seat 7. Headlight changed in 86 to include different headlight bucket, top frame that mounts dash, adjustment mech, left side upper frame and headlight ring 8. passenger foot boards added 9. Muffler mount spacer larger 10. OEM CB added 11. chin scoop out of ABS 12. Engine guards redesigned to take new scoop 13. Windshield chrome strip changed to one piece 14. wider fork mount for 100mm calipers 15. Front brake and gear shifter non-adjustable. 16. clutch springs, pressure plate changed. 17. extra bleeder valve for left front brake near ignition switch. 18. Cruise Control lights on ignition switch cover. 19. Electrical anti-dive. 20. Longer drive shaft and modified final. 1987 1988 1. Standard XVZ1300 Discontinued 1989 1990 1. front fork boots attach a at the bottom. 2. TCI changed 1991 1992 1993 1994 1. European only 1986: Heavier rear linkage mounting braces Rear crash bar mounts located higher on seat frame Non removable top and side boxes Venture cruise gained accel/decel functions
KIC Posted August 14, 2015 #52 Posted August 14, 2015 Great idea. Love reading about the differences. Just remember to finish the list with the differences between the 1st Gen and 2nd Gen: 1st Gen: Fastest 2nd Gen: Slower:bang head:
