Guest Katydid Posted April 6, 2007 Share #1 Posted April 6, 2007 Does anyone know of a source for generic handlebar mounted switches for accessories? Thanks, Dave Link to comment Share on other sites More sharing options...
Eck Posted April 6, 2007 Share #2 Posted April 6, 2007 Is this what you mean , or is this what you are looking for in an accessory switch?? If so, check JC Whitney.. Link to comment Share on other sites More sharing options...
Guest Katydid Posted April 6, 2007 Share #3 Posted April 6, 2007 YES thats what I'm looking for...I didnt see these on the JCW website, but I'll go look again. Thanks, Eck Link to comment Share on other sites More sharing options...
Tartan Terror Posted April 6, 2007 Share #4 Posted April 6, 2007 If you want black this is from JP cycles. http://www.jpcycles.com/productgroup.aspx?GID=3142C9E1-A621-49FF-8C17-D45A222B0955 Or this. http://www.hellrisercustoms.com/selector.php?group=7&category=Handlebars&subcat=Brakes&title=Handlebar Link to comment Share on other sites More sharing options...
Guest scooter38 Posted April 6, 2007 Share #5 Posted April 6, 2007 I bought mine from http://www.CruiserCustomizing.com thought I rewired it and put better switches on it too, cause the way it is all three switches are hooked up from one power wire. Link to comment Share on other sites More sharing options...
Guest Katydid Posted April 6, 2007 Share #6 Posted April 6, 2007 Thats exactly what I needed...thanx, Scott(s) for the links. Dave Link to comment Share on other sites More sharing options...
Leland Posted April 7, 2007 Share #7 Posted April 7, 2007 www.bigbikeparts.com has the switch for the left side (clutch). Link to comment Share on other sites More sharing options...
Guest Katydid Posted April 7, 2007 Share #8 Posted April 7, 2007 Bigbikeparts website is under construction Link to comment Share on other sites More sharing options...
Carbon_One Posted April 7, 2007 Share #9 Posted April 7, 2007 I have one from JCW too. Mounted it over the clutch resvoir. No power going thru the switches thou. I have it wire stricly as a grounding switch for the relay running the low beam headlight, spots , and bullet gauge lights Larry Link to comment Share on other sites More sharing options...
