uechi kid Posted April 19 Share #1 Posted April 19 (edited) I have gas dripping from a tube behind the front left fairing. It's coming from what looks like a feed line for the carburetors. Anyone know what's causing this and how to fix it? Edited April 19 by uechi kid Link to comment Share on other sites More sharing options...
M61A1MECH Posted April 20 Share #2 Posted April 20 Most likely is a stuck needle valve or debris in between the needle and the seat that is not allowing the float to close the valve fully. Some times a dose of Seafoam and a good spirited run will clear that up if it is minor. If a dose of Seafoam or carb cleaner does not fix it, you probably in for a carb overhaul. I am pretty sure the are posts in the tech library to help with this issue. Link to comment Share on other sites More sharing options...
uechi kid Posted April 21 Author Share #3 Posted April 21 Thanks. I’m giveing the Seafoam a try. I’ve never taken a carburetor apart so I’m a little nervous about having to do that. Link to comment Share on other sites More sharing options...
uechi kid Posted May 7 Author Share #4 Posted May 7 Seafoam didn’t do the trick, so I guess it’s time to explore a carb rebuild. Link to comment Share on other sites More sharing options...
etcswjoe Posted May 7 Share #5 Posted May 7 Bang on each bowl with the handle of a screwdriver. If that does not work you just need to take the bowl off and make sure the needle valve seats. Link to comment Share on other sites More sharing options...
uechi kid Posted May 8 Author Share #6 Posted May 8 (edited) 20 hours ago, etcswjoe said: Bang on each bowl with the handle of a screwdriver. If that does not work you just need to take the bowl off and make sure the needle valve seats. I hate to sound so ignorant but, can you point out the float bowl and drain valve? And do the carbs need to be removed to do this? Thanks. Edited May 8 by uechi kid Link to comment Share on other sites More sharing options...
Marcarl Posted May 9 Share #7 Posted May 9 Seafoam although a good product often does not do the trick. Best get a spray can of carb cleaner and spray the whole can into 1/4 tank of fuel. Once installed start the engine, run it on choke for a bit, then let it run for about 20 minutes every once in a while running the rpms up to 2000 for a minute or so. Shut it off, let cool and do it all again. 3 times is good. Now fill the tank and go for a ride keeping the rpms up. Could be a problem solver. 1 Link to comment Share on other sites More sharing options...
uechi kid Posted Wednesday at 06:40 PM Author Share #8 Posted Wednesday at 06:40 PM On 5/9/2024 at 8:24 AM, Marcarl said: Seafoam although a good product often does not do the trick. Best get a spray can of carb cleaner and spray the whole can into 1/4 tank of fuel. Once installed start the engine, run it on choke for a bit, then let it run for about 20 minutes every once in a while running the rpms up to 2000 for a minute or so. Shut it off, let cool and do it all again. 3 times is good. Now fill the tank and go for a ride keeping the rpms up. Could be a problem solver. Use the spay carb cleaner rather than the stuff similar to sea foam that’s designed to go in the tank? Link to comment Share on other sites More sharing options...
Marcarl Posted Wednesday at 08:11 PM Share #9 Posted Wednesday at 08:11 PM 1 hour ago, uechi kid said: Use the spay carb cleaner rather than the stuff similar to sea foam that’s designed to go in the tank? That's what I use, seems to do a better more thorough job. Link to comment Share on other sites More sharing options...
