I've just started to notice a backfire when I downshift hard. I haven't done anything to the carbs so I thought it mights have something to do with that. Can this generally be fixed by syncing?
I know the collar on the rigt side is loose at the muffler and the collector has some loose baffles. Would that cause the backfire?
If the collector has any leaks (ie holes), then it will suck in additional oxygen and cause the fuel rich gasses inside to explode, causing a backfire. Had this happen on my '85 (backfiring) and when I took the collector off, there were splits where the mounting brackets were attached. I'd suggest removing the collector and thoroughly inspecting it for leaks. Might be a good time to cut it open and get rid of those loose & rattly baffles.
Thanks. It sounds like a pretty easy fix. Now I just need to find a way to get it done. Anyone know a welder in Buford GA?? :whistling:
btw... make sure the welder you find can weld stainless steel ... did you find the post in here about how to open up the collector and remove the baffles? I know there's one someplace coz that's what I used.
Yes I saw that thread. It looks pretty easy except I don't have a torch. It's too bad duct tape won't work.:confused24:
a torch for what??
If you're referring to cutting it open, I used a cutting wheel on my hand held grinder .. probably could also use it on a drill.
BTW, I tried the duct tape approach... it's only good when the exhaust is cold! LOL
You don't have to do anything special to weld it. When I did mine we just used a mig welder with regular wire.
Chip, if you take the collecter off and bring it to Marietta, we can open it and close it back up. You'll just have to buy my buddy lunch and maybe a six pack!
Edited by 86er
I can definately do the lunch Todd. If I rode out there do you think some water would cool it enough to pull it? The next few weekends are pretty tight but I could get it there in July. What do you think?
Maybe if you rode over and we did lunch while it sat and cooled. That should work. Would need to be a Sunday or Monday as I work Tues thru Sat.
As far as the backfiring, you probably need a carb sync as well. Especially if it's been a while. Yamamama recomends 2500 miles. I'm lucky to get it by 25000!
Edited by 86er
welll... that's news to me...I was going by other information I found on this topic when I had mine welded. Since I'm no welder, I can't comment but when someone says to me that it's made out of stainless steel and you need a welder who knows how to weld stainless steel...then that's what I do. ???????
:think:
All the better if it's nothing special and any welder who can run a mig welder can do it.
Don't use a Dremel. Yea it will work but it will burnt the guts up. I ended up buying a new Dremel. Can't be without one of those!
That would work for me. I'll contact you in a few weeks and we can set it up. Do you have the tood to sync the carbs as well? That would be great to knock it out in one trip. (I do need to go ahead and get one though)
