GigaWhiskey Posted June 2, 2008 Posted June 2, 2008 Will an 85 wheel fit an 86? Reason I ask, is Lonestarmedic's 86 has a shimmy issue. So, I was thinking if I took my wheel off (tire, rim, disc's, ect... in one piece), can we put it on his to help determine if it is the tire (or whatever) or not. if you are gonna ask, I have the single piston calipers I guess, the older better looking ones.
Rocket Posted June 2, 2008 Posted June 2, 2008 Will an 85 wheel fit an 86? Reason I ask, is Lonestarmedic's 86 has a shimmy issue. So, I was thinking if I took my wheel off (tire, rim, disc's, ect... in one piece), can we put it on his to help determine if it is the tire (or whatever) or not. if you are gonna ask, I have the single piston calipers I guess, the older better looking ones. I think the difference, between them, is only the brake rotors.
GigaWhiskey Posted June 2, 2008 Author Posted June 2, 2008 Maybe if Goose comes by, we can check the balance too!
Squidley Posted June 2, 2008 Posted June 2, 2008 It will interchange besides the rotors like Rocket mentioned
bongobobny Posted June 2, 2008 Posted June 2, 2008 You are talking front only, right? I'm not sure the rears are interchangable without changing rotors AND differential gears (not 100% sure on the gears but I do know the rear ends are not compatible...
GigaWhiskey Posted June 2, 2008 Author Posted June 2, 2008 Yea, front only. Just wanna help him figure out where the front end shimmy might be coming from on the 21st. So. figured i would be willing to let him try my wheel to check it out.
