Rear brake issues
Hey guys, I just purchased a new to me 83 venture 1200. The rear brake pedal is extremely hard to push and I have to pull back up. The reservoir was dry, I added some DOT 4 and sprayed some penetrating oil on the pedal up to the master cylinder.
am I missing a place to make an adjustment? I was hoping the brake fluid would help loosen it up.
Those rear master cylinders build up with crud if fluid is very old and contaminated with moisture  so yes rebuild is likely but don't  be surprised if they are corroded inside meaning full replacement. So before you invest in a kit pull it apart clean it and thoroughly inspect every piece. Including the proportioning valve.
  • Like 1
