shooter3001 Posted May 13, 2008 Share #1 Posted May 13, 2008 Has anyone else experienced this. I have an 07 RSV with 3800 miles on it. This problem just started over the weekend. As I was going down the road I tryed to turn on the radio and it wouldn't come on. Tryed the cb, same thing. It was like it wasn't getting power just a blank. So I pulled over, turned the ignition off and turned it back on and the radio worked. Since then it has done the same thing a few more times with the same results, Turn ignition off and back on and the radio works. Tryed wiggling the cable going to the radio and that didn't fix it. The only thing that works is to turn the bike off and then back on, press the on button and it works. Has anyone else had this problem? I'd like to give the dealership some type of direction to look, seeing that they don't work on too many of the Ventures. Any help is appreciated. Link to comment Share on other sites More sharing options...
Aimhigh Posted May 14, 2008 Share #2 Posted May 14, 2008 Shooter, I, too, have an '07 and have experienced the same problem. I had the dealer look at it...of course, they could not duplicate the problem. Recently I started out, got about a block away and the overheat and oil indicators came on. I turned around and drove to work...that night, nor since, has that occurred again. I think this particular model may have some electrical problems...time will tell. In the meantime, I never turn off the radio and it always has come right on when I start the bike. Jim T Link to comment Share on other sites More sharing options...
dragerman Posted May 14, 2008 Share #3 Posted May 14, 2008 Has anyone else experienced this. I have an 07 RSV with 3800 miles on it. This problem just started over the weekend. As I was going down the road I tryed to turn on the radio and it wouldn't come on. Tryed the cb, same thing. It was like it wasn't getting power just a blank. So I pulled over, turned the ignition off and turned it back on and the radio worked. Since then it has done the same thing a few more times with the same results, Turn ignition off and back on and the radio works. Tryed wiggling the cable going to the radio and that didn't fix it. The only thing that works is to turn the bike off and then back on, press the on button and it works. Has anyone else had this problem? I'd like to give the dealership some type of direction to look, seeing that they don't work on too many of the Ventures. Any help is appreciated. I’ve had a similar problem to this where the radio controls would work intermittingly and the display would fade in and out. It seemed like a bad connection so I spit the fairing located the connecter for the radio controls. Then I separated the connector, sprayed each side with contact cleaner then blew the ends dry with compressed air. To take the radio connectors apart you have to slide the rubber covering back and look for a little tab. Press the tab and it will allow you to pull apart the connector. Before I put it back together I pressed some Dielectric Grease in the female end... I haven’t had a problem since. While I was at it I did all the other connectors as well. Link to comment Share on other sites More sharing options...
r12guy Posted May 16, 2008 Share #4 Posted May 16, 2008 Mine would fade in and out, the display would change and i would have no control of the radio at all. The knuckle head at the dealer couldnt get it to do it, so i had to keep mental notes and keep after him. I kept telling him it was the remote and not the radio. well low and behold one day while taking it in for service it di it and i just parked the bike and left it running so they could see i wasnt dreaming. Seems they had to get the whole radio kit in to just replace the head. And Yamaha was a little upset with them because they are to send it to Clairion and get rebuilt. I didnt care, my tunes work again. Link to comment Share on other sites More sharing options...
edeas62 Posted May 7, 2016 Share #5 Posted May 7, 2016 Im having the exact same problem with my 06. I guess Im also taking the front fairing off and will follow your advice. Thank you Link to comment Share on other sites More sharing options...
Oilseal21 Posted August 11, 2016 Share #6 Posted August 11, 2016 I just bought a 03 midnight venture but I can't get the radio to come on at all tape works cb works but no sign of the radio anyone got any ideas? Link to comment Share on other sites More sharing options...
Du-Rron Posted August 11, 2016 Share #7 Posted August 11, 2016 No static or anything with the volume turned up? Does the display cycle to am and fm? Link to comment Share on other sites More sharing options...
Freebird Posted August 11, 2016 Share #8 Posted August 11, 2016 I assume you have the manual and have learned how to switch between tape, aux, radio and etc? If so, my next step would be to pull the front off the fairing and check all the connectors in the big plugs. Link to comment Share on other sites More sharing options...
