fltmedic Posted October 6, 2019 Posted October 6, 2019 3 weeks ago I used the electronic system to unlock my saddle bag and it would not unlock. Tried using the key like the manaul stated without luck. Took to the local dealer who tried and called Yamaha. Short story is if the clip that holds the selenoid is not placed correctly during manufacture or if it becomes dislodged in any why the selenoid will drop out of place and the only way to get into the saddlebag involves using a saw to cut the top of the bag away where the locking mechanism attaches. Fortunately this was a warrantee repair, otherwise it would have run over $1000 including labor! Unfortunately parts took nearly two weeks. The dealership informed me that Yamaha has had a few issues with this.
sldunker Posted October 6, 2019 Posted October 6, 2019 May have to take a look at this and see if something can be done so it don't happen. Thanks
captdrac Posted November 4, 2019 Posted November 4, 2019 I ran into the same problem on the way to Americade last year. The right saddlebag wouldn't open & I couldn't get to my clothes (fortunately my wife's clothes were in the left saddlebag). We left on a Saturday, and the problem started that night. We didn't get it fixed until Wednesday because when we arrived Monday, the nearest Yamaha dealer was closed Mondays. When Americade started Tuesday, I went to the Yamaha display and Adrian (Yamaha rep) knew of the problem and expedited the parts overnight. He ordered the parts for both locks because I started having problems w/ opening the left side. The local Yamaha service dept took me in right away Wednesday and repaired both sides. It was weird to see the new right saddlebag get cut open w/ a sawall and hole saw.
Dhansonrrt Posted November 18, 2019 Posted November 18, 2019 Same problem here with the left saddle bag. Yamaha replaced lid and locking assembly. They are very aware of the issue
fltmedic Posted June 27, 2020 Author Posted June 27, 2020 My suggestion to all to if you have one fail make them replace both saddlebag locks... My left Saddle bag lock just failed today. Called my local Yamaha dealer and they will try to get the parts expedited from Yamaha on Monday... If Yamaha knows this is an issue why aren't they dealing with it better?
ZephyrChuck Posted June 29, 2020 Posted June 29, 2020 I will be taking a look at this, also. It must be a ***** to not be able to get into your saddlebag when you need to. Especially, if you carry your wallet and other needed things in there, like I do.
