uhfradarwill Posted August 18, 2018 Posted August 18, 2018 Anybody have a pic of the location of the mixture adjustment screw? I did a carb sync and would like to check to see where the mix screws are set to but I don't know where they are located! Thanks
BlueSky Posted August 18, 2018 Posted August 18, 2018 It's on the side and easily accessible to adjust with the engine running. Part 19 in the diagram https://www.partzilla.com/catalog/yamaha/motorcycle/1989/venture-royale-xvz13dw/carburetor-non-california-model
Bob K. Posted August 18, 2018 Posted August 18, 2018 (edited) Here ya go: https://www.venturerider.org/forum/showthread.php?112729-How-to-access-idle-screw. That post calls them "idle screws" but they're offiically called pilot screws. If yours are still covered with the brass plugs, drill a little hole in the plug, tap it with a screw, and pull the plug out. Edited August 18, 2018 by Bob K.
Prairiehammer Posted August 18, 2018 Posted August 18, 2018 Anybody have a pic of the location of the mixture adjustment screw?
Patch Posted August 19, 2018 Posted August 19, 2018 High Will, I did try to reply to your pm on this, not sure if you received it. Anyways as I recall from your other post with the picture of the side view of your carbs, those tamper caps appeared to be off, the head of the crew seemed to be visible. Let us know how it works out
uhfradarwill Posted August 20, 2018 Author Posted August 20, 2018 High Will, I did try to reply to your pm on this, not sure if you received it. Anyways as I recall from your other post with the picture of the side view of your carbs, those tamper caps appeared to be off, the head of the crew seemed to be visible. Let us know how it works out Thanks everyone! My caps are off and I'm about to go see where they are set at. I guess I'll just go with the 2.5 turns out. Will
bongobobny Posted August 20, 2018 Posted August 20, 2018 ***SIGH*** In order to properly set your mixture screws, you need to use either a colortune plug or a CO sniffer. There is a reason the factory put those caps on over the adjusters. Just turning them out some arbitrary amount will most likely unbalance the mixture making the bike run less efficient and emit more pollutants into the atmosphere...
Patch Posted August 20, 2018 Posted August 20, 2018 The short version for me: Turn one pilot screw in till bottoms out Note the turns it took Note if the engine has slowed rpms/ if yes then assume that pilot circuit is working I then turn that pilot out 1 & 1/4 turn/ wait 8 seconds rpm have picked up? Then turn in 1/4 turn do rpm's slow? If so then turn out 1/2 turn, rpm should pickup (again wait 8 seconds) Now back in 1/8 turn looking for increasing rpm if it slowed then out 1/4 (8 seconds) So after the initial setting to 1 &1/4 all you need do is tweak the pilot screw back and forth as mentioned till you have reach the highest rpm possible. This is in most cases around a 1/4 turn in or out of the initial set, and providing the jets are standard, and not partially clogged, such as slow gains can likely be a sign of restricted jet passage. Do not adjust rpm set screw while setting pilot screws. I start between 800- 850 rpm, after all are done I adjust final rpm. The final 1/4 turn after all have been set, is not mandatory it is simply a buffer nor must it be a 1/4 turn 1/8 might suit you. Whether you finish in or out on this final depends on what you prefer lean ish or rich ish Keep in mind the pilot circuit is not a power circuit, it is idle and transition to power circuits. And yes it stays on all the way through so does contribute.
