Toeman Posted July 3, 2018 Posted July 3, 2018 My 2008 RSV came with a aftermarket driving (passing lights.) does anyone happen to know if there is a LED replacement that will fit in the same enclosure. thank you
RandyR Posted July 3, 2018 Posted July 3, 2018 You'll need to supply more information. There are 2 types of Yamaha driving lights and dozens of 3rd party lights.
Sylvester Posted July 3, 2018 Posted July 3, 2018 My 2008 RSV came with a aftermarket driving (passing lights.) does anyone happen to know if there is a LED replacement that will fit in the same enclosure. thank you Are they 4.5 inch lenses. If so there are many out there. I got mine from Larsen Lights. They have the seven LEDs with six in a circle around the center one and they really light the road. Get the traphazoydal spot.
djh3 Posted July 4, 2018 Posted July 4, 2018 If they are the standard sized jobs @ 4.5" they are a PAR 36 bulb I think is what they call them. So any bulb LED or incandesant will work. Some have used the LED work lights from Northern Tool
djh3 Posted July 5, 2018 Posted July 5, 2018 Here are a couple. https://www.ebay.com/itm/HANDXEN-LED-Landing-Taxi-Light-PAR-36-GE-4509-REPLACEMENT-FLOOD/162831503960?hash=item25e9839258:g:iuQAAOSwtnBa8wt7 https://www.northerntool.com/shop/tools/product_200615334_200615334 Pop the light out and install in your housing.
leroy Posted July 7, 2018 Posted July 7, 2018 I replaced my PAR 36 driving/fog/passing lights whatever one calls them with Truck Lites. I believe they are the 81260. They are great at lighting up the road. These are more of a flood than a spot. So the sides of the road are lit up better. They draw about half the power of the PAR 36 but much brighter and whiter.
