leo3wheel Posted April 21, 2017 Share #1 Posted April 21, 2017 Custom Dynamics makes LED replacement for turn signals that allows them to function as both turn signals and driving lights. Switching from light bulbs to LED's affects the blinker rate. To correct this, Custom Dynamics recommends a load equalizer, 7.5 ohms to ground on each light. They caution that unit gets hot, and recommend that unit be mounted under seat. Any suggestions on how to locate unit under seat and tie into signal wires with the posi-locks? Thanks! "Universal 7.5 Ohm* Metric Turn Signal* Load Equalizer w/ connectors *Simple locate the turn signal wires and snap into place with the supplied connectors. The load equalizer produces and equivalent load of a 7.5 ohms (1.9 amps @ 14VDC), therefore the unit will get* hot. Caution: This load equalizer will get hot, please mount accordingly. Suggested Mounting - Under seat securely mounted to frame rail. Installation: Connection one purple to left turn, remaining purple to right turn, black to ground. Posi-locks are included for quick connections. One load equalizer is needed for each pair of turn signal that are replaced with LEDs on most Metrics." Link to comment Share on other sites More sharing options...
Bert2006 Posted April 21, 2017 Share #2 Posted April 21, 2017 I used a quad load equalizer and placed it under the passenger seat on top of the rear fender. This way the heat sink contacts the fender directly and offloads the heat. At this spot it was easy to connect to rear harness but I had to run separate wires to the front lights in the channels under the gas tank. Hope this helps. I attached a pic of the quad equalizer. Its from Big Bike Parts. Link to comment Share on other sites More sharing options...
leo3wheel Posted April 21, 2017 Author Share #3 Posted April 21, 2017 Have to pull my seat and tank anyway, so I'll see what I can do. Since I have a trike, there is no metal fender, but should be able to find some metal. Thanks Bert! Link to comment Share on other sites More sharing options...
M61A1MECH Posted April 22, 2017 Share #4 Posted April 22, 2017 Positaps are fine connections, much better than those Scotch-lok guillotine type taps, but here is another option that will work under the seat and is even less invasion to the wires. Take one of my aux harness set ups and take the left and right turn signal leads to the heat sink, makes it all very plug and play and no chance of damaging the wire harness. Plus it gives you ready access to the other signal wires if you want to add more lights later. One of the guys on the Stratoline forums did this and said it worked great. Here is a link to my ad for a Venture style harness, http://www.venturerider.org/forum/photopost/showproduct.php?product=4&title=aux-lighting-harness-for-2nd-gen-venture&cat=18 Link to comment Share on other sites More sharing options...
leo3wheel Posted April 22, 2017 Author Share #5 Posted April 22, 2017 Steve, This is a great idea! Do you have a pic showing where aux harness would be inserted? Thanks! Link to comment Share on other sites More sharing options...
leo3wheel Posted April 22, 2017 Author Share #6 Posted April 22, 2017 Okay, now understand where aux harness is attached. Trike has LED taillights/turn signals and light bulb front running lights/turn signals. Not sure if rear is isolated from front. Wonder if load equalizers are required by front turn signals. Guess I could order the LED's and try them without the load. Unsure? Link to comment Share on other sites More sharing options...
MikeWa Posted April 22, 2017 Share #7 Posted April 22, 2017 I much prefer the flasher mod over the load equalizer. The load equalizer draws current to simulate light bulbs. The flasher mod reduces current flow. Mike Link to comment Share on other sites More sharing options...
M61A1MECH Posted April 22, 2017 Share #8 Posted April 22, 2017 Yes the flasher mod is also an excellent way to go. One suitably sized load resistor for each side, attached to my aux harness will take care of front and rear, the front and rear circuits are connected as one circuit. Here is a link that may help. https://www.superbrightleds.com/moreinfo/flashers-load-resistors/led-light-load-resistor-kit-led-turn-signal-hyper-flash-warning-fix/190/ Link to comment Share on other sites More sharing options...
leo3wheel Posted April 22, 2017 Author Share #9 Posted April 22, 2017 Thanks Steve! If I choose to go the flasher mod route, can someone give me a part #/ source. Thanks! Link to comment Share on other sites More sharing options...
M61A1MECH Posted April 22, 2017 Share #10 Posted April 22, 2017 Here is a video for doing it, I am pretty sure the folks over on the Delphi forum have the process documented, Check with TANK over there. Link to comment Share on other sites More sharing options...
leo3wheel Posted April 22, 2017 Author Share #11 Posted April 22, 2017 Hi Steve, Does not appear to be a flasher mod for Gen 2. Don't see any 5-pin flasher relays with compatible pinout. Will use the load equalizer with your Gen 2 harness. Sent you email. Thanks, Leo Link to comment Share on other sites More sharing options...
leo3wheel Posted April 22, 2017 Author Share #12 Posted April 22, 2017 All parts ordered... Link to comment Share on other sites More sharing options...
M61A1MECH Posted April 23, 2017 Share #13 Posted April 23, 2017 Hi Steve, Does not appear to be a flasher mod for Gen 2. Don't see any 5-pin flasher relays with compatible pinout. Will use the load equalizer with your Gen 2 harness. Sent you email. Thanks, Leo So I just got a copy of the procedure for the Venture flasher from Tank over on the Delphi forums. Freebird, maybe this is something to add to the Second Gen Read only tech section.turn signal mod for LEDs.pdf Link to comment Share on other sites More sharing options...
leo3wheel Posted April 23, 2017 Author Share #14 Posted April 23, 2017 Steve, Flasher mod looks like a great way to go. Had the flasher in hand but couldn't open it. I was concerned about damaging it. Now I have a dilemma. Please hold off on sending me the aux harness. I'll take another look at the flasher to see if I can make sense of it. Thanks! Link to comment Share on other sites More sharing options...
leo3wheel Posted April 23, 2017 Author Share #15 Posted April 23, 2017 Ordered resistor to perform flasher mod. Link to comment Share on other sites More sharing options...
Freebird Posted April 23, 2017 Share #16 Posted April 23, 2017 So I just got a copy of the procedure for the Venture flasher from Tank over on the Delphi forums. Freebird, maybe this is something to add to the Second Gen Read only tech section. Done. Link to comment Share on other sites More sharing options...
MikeWa Posted April 23, 2017 Share #17 Posted April 23, 2017 Ok this is something I have posted about before. If you open the flasher. Cut the bare wire as seen in the photographs and solder in a .33 ohm resistor it will slow the flasher rate. Mike Link to comment Share on other sites More sharing options...
leo3wheel Posted April 23, 2017 Author Share #18 Posted April 23, 2017 Thanks Mike! Waiting for parts to come in. Link to comment Share on other sites More sharing options...
leo3wheel Posted April 26, 2017 Author Share #19 Posted April 26, 2017 Okay, resistors are here. Just need the LED's. Link to comment Share on other sites More sharing options...
leo3wheel Posted April 26, 2017 Author Share #20 Posted April 26, 2017 Play Time! Link to comment Share on other sites More sharing options...
bongobobny Posted April 27, 2017 Share #21 Posted April 27, 2017 I actually had one of mine have a direct short and it immediately blew a fuse!! No problems whatsoever with warranty exchange... Link to comment Share on other sites More sharing options...
leo3wheel Posted April 27, 2017 Author Share #22 Posted April 27, 2017 Wow! That would rain on my parade! Link to comment Share on other sites More sharing options...
DblTrbl Posted April 27, 2017 Share #23 Posted April 27, 2017 Play Time! Leo, let me know how it works out for you. I have been thinking about going with those lights for brake and turn signals but was nervous about messing with the mods... Thanks Dennis Link to comment Share on other sites More sharing options...
leo3wheel Posted April 27, 2017 Author Share #24 Posted April 27, 2017 Will do Dennis. Link to comment Share on other sites More sharing options...
leo3wheel Posted April 27, 2017 Author Share #25 Posted April 27, 2017 Okay, all trike lights are LED, except dash lights. Not sure flasher mod or load equalizers are necessary for turn signals. Looks okay to me, and leaves motorcycle with standard flasher. On to next project... Link to comment Share on other sites More sharing options...
