Jdafixa Posted February 24, 2017 Posted February 24, 2017 Hey all, I'm sure this has been covered but I havent been on in a while. I have small hands and my clutch hand gets pretty fatigued in traffic. I'm not familiar enough with hydraulic clutches and wonder if I can adjust the stroke or something to reduce the span or the tension on the lever, or if I just have to live with it? It's not a deal breaker, but it does get pretty crampy feeling . Any advice will as always be greatly appreciated.
Flyinfool Posted February 25, 2017 Posted February 25, 2017 Here is a recent thread on this issue. http://www.venturerider.org/forum/showthread.php?112819-LIttle-girl-hands-big-bad-clutch&highlight=clutch
djh3 Posted February 25, 2017 Posted February 25, 2017 Hyd clutch you kinda got what you got. To change the draw (throw) you would have to change the pivot point. Or maybe a larger clutch master (diameter of bore) in conjunction with off set throw handle. My cable clutch on the Victory was really stiff. Especially right where I didnt need it to be, in that partially engaged slow traffic area. Luckily someone make a lever to put on that changes the angle on the cable pull to make it a little easier.
bongobobny Posted February 25, 2017 Posted February 25, 2017 There are some wide blade aftermarket handles for the clutch and brake that I use and am happier with the feel of over the stock ones...
