woz111 Posted April 19, 2008 Posted April 19, 2008 I'm having trouble starting the bike up, as it didn't have any HT leads I had to buy a new set and I'm not sure that I've put them on correctly. Could someone please tell me how they should be set up? Left spark plug 1 = Front Left Coil, Right Spark Plug 1 = Front Right Coil 3 Left Spark Plug 2 = Rear Left Coil, Right Spark Plug 2 = Rear Right Coil 4
Rocket Posted April 19, 2008 Posted April 19, 2008 I'm having trouble starting the bike up, as it didn't have any HT leads I had to buy a new set and I'm not sure that I've put them on correctly. Could someone please tell me how they should be set up? Rear coils to rear cylinders on same side, same with front coils. Make sure there is a good tight contact, between the wire core & connectors on each end. Also check TCI & coil plug in connectors for clean contacts. There could be other issues, for the bike not running, but this gives you a starting point.
woz111 Posted April 19, 2008 Author Posted April 19, 2008 Thanks, I'll give it another go, I have set them up right. The bike's just being a ***** to start, new plugs, caps and HT leads, if failing this I may try cleaning the carbs.
Squeeze Posted April 19, 2008 Posted April 19, 2008 fireing Order is 1-3-4-2 Cylinders are: hl = #1 fl = #2 hr = #3 fr = #4
