sho_greg Posted September 7, 2016 Posted September 7, 2016 Looking at wiring schemail for 99 venture. It shows a fuse between the fuel indicator and rectifier... Kind of weird.. anyone know where it is? Maybe this will fix my gauge that is flashing from both ends...
bongobobny Posted September 7, 2016 Posted September 7, 2016 Besides the main fuse, there are two fuse blocks, both on the right side of the bike. One is under the false battery cover, and the other is inside the lower fairing... Hope that helps!
M61A1MECH Posted September 7, 2016 Posted September 7, 2016 Looking at wiring schemail for 99 venture. It shows a fuse between the fuel indicator and rectifier... Kind of weird.. anyone know where it is? Maybe this will fix my gauge that is flashing from both ends... Fuel gauge segments flashing are probably a faulty code, I know when the sending unit goes bad it flashes a code using the gauge segments. Watch them to see if there is a pattern, like a few flashes then pause and then 2 or 3 more flashes, those codes are in the repair manual in the troubleshooting section.
bongobobny Posted September 8, 2016 Posted September 8, 2016 Yah! What Steve said! Sorry, didn't read your first post close enough, sounds like your fuel gauge is trying to talk to you...
snyper316 Posted September 8, 2016 Posted September 8, 2016 Here is good one I put in 1157 long life low voltage type and Everytime I hit the brake I get a warning... Sent from my Z812 using Tapatalk
bongobobny Posted September 8, 2016 Posted September 8, 2016 Which warning Icon?? The 2nd gen "warnings, as it were, are through the fuel tank, and usually has to do with pollution issues...
sho_greg Posted September 8, 2016 Author Posted September 8, 2016 Mine just flashes both ends.. no pauses.. just flash flash glash... doesn't stop...
