Dragonslayer Posted September 26, 2016 Posted September 26, 2016 Coming soon... These battery/starter cable upgrade will be available in a few days (I'm busy, slammed at work) They will be available on the Member Vendors forum as soon as I have the time to do the write up. I plan to install a set on Big Red and do a Tech Article on how to install them as well as how to make them yourself if you so chose. I recently upgraded the cables on Big Red which why I decided to do this. But these cables are hands down far superior to the ones I installed on Big Red last month. So I'm going to go ahead and do it again. Nothing but the best for my Big Red! 4 AWG Welding cable Tin plated copper lugs/terminals Plug-n-Play OEM style quick disconnects on the system positive lead and system/frame ground lead 90⁰ terminal on positive battery lead Slim heavy duty lugs on lower ends for ease of pulling through the motorcycle Additional Positive and Negative/Ground leads for your personal use such as horns or lights. Adhesive lined 3-1 Polyolefin heat shrink. Marine grade Ten ton hydraulic crimp backed up with solder/tinning on open ends This will be a limited production. I have enough supplies for about a dozen sets total. After that I have no idea whether or not I will do another run. In order to be relatively cost effective I have to order in significant quantities and so demand will dictate future production. Check em out. [ATTACH=CONFIG]107502[/ATTACH] [ATTACH=CONFIG]107503[/ATTACH] Looks like a greAt set done right. To bad I don't need any right now.
Not That Guy Posted September 26, 2016 Posted September 26, 2016 Looks great. Will paypal straight away...
yamagrl Posted September 27, 2016 Posted September 27, 2016 Looks great. Will paypal straight away... You got it! There are also a couple more sets that are already spoken for.
syscrusher Posted September 27, 2016 Posted September 27, 2016 You got it! There are also a couple more sets that are already spoken for. I'm a very price sensitive shopper who doesn't really, really need these right now but I went back through the thread and couldn't find where you had set the price. How much?
yamagrl Posted September 27, 2016 Posted September 27, 2016 I'm a very price sensitive shopper who doesn't really, really need these right now but I went back through the thread and couldn't find where you had set the price. How much? They will be $59us plus shipping
syscrusher Posted October 1, 2016 Posted October 1, 2016 Looks like a greAt set done right. To bad I don't need any right now. My thoughts exactly.
snyper316 Posted October 4, 2016 Posted October 4, 2016 Coming soon... These battery/starter cable upgrade will be available in a few days (I'm busy, slammed at work) They will be available on the Member Vendors forum as soon as I have the time to do the write up. I plan to install a set on Big Red and do a Tech Article on how to install them as well as how to make them yourself if you so chose. I recently upgraded the cables on Big Red which why I decided to do this. But these cables are hands down far superior to the ones I installed on Big Red last month. So I'm going to go ahead and do it again. Nothing but the best for my Big Red! 4 AWG Welding cable Tin plated copper lugs/terminals Plug-n-Play OEM style quick disconnects on the system positive lead and system/frame ground lead 90⁰ terminal on positive battery lead Slim heavy duty lugs on lower ends for ease of pulling through the motorcycle Additional Positive and Negative/Ground leads for your personal use such as horns or lights. Adhesive lined 3-1 Polyolefin heat shrink. Marine grade Ten ton hydraulic crimp backed up with solder/tinning on open ends This will be a limited production. I have enough supplies for about a dozen sets total. After that I have no idea whether or not I will do another run. In order to be relatively cost effective I have to order in significant quantities and so demand will dictate future production. Hey I have a question for you. Where are you finding the connectors at? I am trying to find the connectors for my CMS with the pins. Mine is loose. Been also trying to find the tool to take the plugs apart because I can't Fit my small screwdriver up there to release the tab to maybe tighten mine back up.
yamagrl Posted October 5, 2016 Posted October 5, 2016 Hey I have a question for you. Where are you finding the connectors at? I am trying to find the connectors for my CMS with the pins. Mine is loose. Been also trying to find the tool to take the plugs apart because I can't Fit my small screwdriver up there to release the tab to maybe tighten mine back up. It's kind of hard to match some of this stuff up. I haven't found the magic bullet yet, but then I haven't really only looked for the ones on the battery cables. I think I've seen various release tools on all of these sites. Digikey has a great online chat. Easternbeaver has a lot of bike specific stuff. You might wanna look there first. http://www.digikey.com/en http://terminalsupplyco.com/ http://www.easternbeaver.com/ Side note: Been slammed at work and haven't had time to install cables on Big Red and write the Tech article about making the cables and installing them. I feel strongly that accurate installation instructions be part of the package.
bongobobny Posted October 5, 2016 Posted October 5, 2016 Ya know Heather, I like your upgrade enough that I might consider upgrading my Squidley upgrade with yours...
yamagrl Posted October 5, 2016 Posted October 5, 2016 Ya know Heather, I like your upgrade enough that I might consider upgrading my Squidley upgrade with yours...I really have devoted a lot of energy, time and expense to design a really good set of battery cables. I've ordered and tried various tools, supplies and methods. I've returned supplies that I didn't like and finally arrived at what what I believe is excellent indeed. I plan on on being at @van avery's SE Texas Maintenance Day n the weekend of Oct 15th. I'll take a set with me so I'm certain that someone there will be able to post some comments about them. YG
yamagrl Posted October 6, 2016 Posted October 6, 2016 I haven't listed the cables on the Member Vendors forum yet because I haven't done the Installation Instructions and Tech Article yet (due to my overloaded work schedule). But, if anyone needs them before they are listed in Member Vendors just PM me.
yamagrl Posted October 30, 2016 Posted October 30, 2016 The cables are now listed on the Member Vendors under Classifieds. If you are considering a set here they are. http://www.venturerider.org/forum/photopost/showproduct.php?product=761&title=starter-2f-battery-cables-4awg-upgrade&cat=31
yamagrl Posted March 28, 2017 Posted March 28, 2017 I have enough supplies to make a few more sets... if there is enough interest The cables are now listed on the Member Vendors under Classifieds. If you are considering a set here they are. http://www.venturerider.org/forum/photopost/showproduct.php?product=761&title=starter-2f-battery-cables-4awg-upgrade&cat=31 http://www.venturerider.org/forum/attachment.php?attachmentid=107732
