Bert2006 Posted September 28, 2015 Share #1 Posted September 28, 2015 Will be installing the Barnett Spring Conversion kit this week on the RSV and want to make sure I have the right torque numbers? 5ft/lbs for the 5 bolts that hold the new springs on the pressure plate 7ft/lbs for the ones that hold the chrome cover on top of the whole clutch assembly Is that correct? Thanks again! Link to comment Share on other sites More sharing options...
Condor Posted September 28, 2015 Share #2 Posted September 28, 2015 I guess it's correct, but snug is about 10ftlbs, and I just snug'm....... Link to comment Share on other sites More sharing options...
CATPower Posted September 29, 2015 Share #3 Posted September 29, 2015 Bert, please let me know how this works for you. I'm on the fence to do the same. My clutch slips when getting hard onto it. Link to comment Share on other sites More sharing options...
Bert2006 Posted September 29, 2015 Author Share #4 Posted September 29, 2015 Bert, please let me know how this works for you. I'm on the fence to do the same. My clutch slips when getting hard onto it. Will do, still waiting for the clutch cover gasket to arrive ...been waiting a week now. Link to comment Share on other sites More sharing options...
bikenut Posted September 29, 2015 Share #5 Posted September 29, 2015 I have been running one in my 06 venture from new. 69,000 miles and love it. I pull a trailer most of the time with no problem. Link to comment Share on other sites More sharing options...
Bert2006 Posted October 2, 2015 Author Share #6 Posted October 2, 2015 Installed it tonight. Spent about an hour scraping the old gasket off and then about 20 minutes installing the new pressure plate and spring kit. On a scale of 1 to 10 I would say its 2 or 3...very easy. It was dark by the time I finished so only took a short test run around the subdivision and all seem ok. Had a small squeak when pulling the clutch at first but that went away after a few pulls. Can wait to take an extended trip this weekend to try it out. A few pictures are attached. Link to comment Share on other sites More sharing options...
Flyinfool Posted October 2, 2015 Share #7 Posted October 2, 2015 Sure is purdy, shame to cover it up. Link to comment Share on other sites More sharing options...
Bert2006 Posted October 4, 2015 Author Share #8 Posted October 4, 2015 Bert, please let me know how this works for you. I'm on the fence to do the same. My clutch slips when getting hard onto it. Well, was able to take it out on a 4 hour run today and no more slip at all. Highly reccomend it! Link to comment Share on other sites More sharing options...
CATPower Posted October 4, 2015 Share #9 Posted October 4, 2015 (edited) Thanks for the update! So all you changed is the pressure plate? Did you use the springs that came with the plate or extra heavy duty springs ? Thanks Edited October 4, 2015 by CATPower Link to comment Share on other sites More sharing options...
Bert2006 Posted October 4, 2015 Author Share #10 Posted October 4, 2015 Thanks for the update! So all you changed is the pressure plate? Did you use the springs that came with the plate or extra heavy duty springs ? Thanks Used the ones that came with it. The clutch plates looked good though so did not touch those. The trickiest part was getting the old gasket off without having peices fall into the clutch plates. Link to comment Share on other sites More sharing options...
CATPower Posted October 4, 2015 Share #11 Posted October 4, 2015 Thanks Time to order one ! Link to comment Share on other sites More sharing options...
