garyS-NJ Posted September 2, 2015 Posted September 2, 2015 I bought my bike without a battery and she's almost ready for the road. I read that the deka battery is the best to replace the stock BTG-GM18Z-3A-S0.. can anyone say where I can buy one in person or get it shipped? I live in Kearny, NJ. and my stock battery had a battery probe (I don't know what that checks...). any issues with a sealed battery? what are the pros and cons.. to a stock style vs sealed battery? and otherwise, what is a good battery and a battery to avoid? without input, I'd be shopping at walmart/
bongobobny Posted September 2, 2015 Posted September 2, 2015 Order your DEKA battery from member Skydoc_17. The probe is a sensor for the electrolyte level in the battery. You will get a warning signal on the dash but that can be overridden by installing a 2K ohm resistor from the probe to the + side of the battery or to the ignition line...
Max Posted September 3, 2015 Posted September 3, 2015 Yep, ditto Bob on that. Deka is the way to go. Don't quote me, but I think it's the '18L'.
cabreco Posted September 8, 2015 Posted September 8, 2015 I bought my 84 & within a year I replaced the battery with a top of the line Autozone unit. I worked for 3 months, after that it would crank down & die off. I replaced it with an Advanced Auto unit. That worked better but if I didn't run the bike every 4 or 5 days is would get too weak to start the bike after I was cranking it for awhile. Then I bought the DEKA from skydoc17. The Price is commensurate with the others and IT WORKS LIKE A DREAM. I leave the bike unstarted for weeks & it fires up. I run ALL the systems & alarms...& it ALWAYS works. I bought that battery 2 years ago, when the time comes...I will get another from SkyDoc17. QUALITY BATTERY! Pull the trigger, you will not regret it. As far as the sensor goes ... http://www.venturerider.org/forum/showthread.php?489-Battery-Warning-Bypass
