SpencerPJ Posted May 22, 2015 Share #1 Posted May 22, 2015 I have stock 83 Venture, 24k miles, and the last couple rides (not always), after sitting maybe a week, when I turn the key, sometimes I do not hear fuel pump click (prime). Today, I did not hear it, started it, it acted like it was starving for gas, I turned it off, key back on, heard maybe 10 clicks (fuel pump) started right up, ran fine all day. So, does this sound like my fuel pump is starting to go bad? OR should I be looking at something else? Link to comment Share on other sites More sharing options...
jdog910 Posted May 22, 2015 Share #2 Posted May 22, 2015 no, its a pressurized system, it will only activate when there needs to be fuel pumped to the carbs. Link to comment Share on other sites More sharing options...
Marcarl Posted May 22, 2015 Share #3 Posted May 22, 2015 Sounds like either a connection or the pump,, could be the fuse holder or maybe even the relay. Do one thing at a time,, first the fuse box\holder, take the fuse out and see if the legs of the holder are solid. If that won't cure it, check your connections, clean them while you're at it. After that, post back with your findings. Link to comment Share on other sites More sharing options...
SpencerPJ Posted May 23, 2015 Author Share #4 Posted May 23, 2015 Ya, I'll start with the connectors, I was hoping others may have had the exact problem and possible solution. Link to comment Share on other sites More sharing options...
Donvito Posted May 23, 2015 Share #5 Posted May 23, 2015 (edited) I have had fuel pump problems on my 87. I believe it is a little different on an 83, but as Marcarl said, there are many different components to the fuel delivery system. On my bike, I used a jumper wire to the final connector before the pump or at the relay connector, and, if it operates properly, you know the problem isn't the pump. Then, if the problem isn't the pump, you can test the other components. Fuel flow to the pump can also have an effect on the pumps operation so a clean fuel filter and petcock filter may help. Edited May 23, 2015 by Donvito Link to comment Share on other sites More sharing options...
10spd Posted May 24, 2015 Share #6 Posted May 24, 2015 Mine was doing the same thing. I changed the fuel filter (the original I think) that helped. I also found the positive battery cable loose. Not exactly sure what did it but is running a whole lot bettet Link to comment Share on other sites More sharing options...
