Rdfroese Posted April 6, 2015 Posted April 6, 2015 The arrow points up on the fuel valve. What does that indicate? What direction do I turn it, it's a bit stuck and I want to turn it the right direction first time. Thanks
BlueSky Posted April 7, 2015 Posted April 7, 2015 Up is RESERVE. Down is ON. Towards the front is OFF.
Jayceesfolly Posted April 7, 2015 Posted April 7, 2015 Be very careful about turning the valve, especially if it has not been used in a while. The plastic can become very brittle due to age and if you use too much force, you may snap off the knob. Work the valve back and forth very gently until it moves freely. In some instances you may have to drain the tank and dis-assemble the valve first. Don't ask me how I know. I now leave the valve in the reserve position all the time and refuel based om MPG. Jim
