Husker88 Posted March 17, 2015 Share #1 Posted March 17, 2015 (edited) My LCD Screen is blank. It has the backlight but no gas gauge, no gear indicators...nothing. How do I reset the LCD screen? Recently replaced Stator, Rectifier/Regulator... Thanks in advance! Edited March 17, 2015 by Husker88 Link to comment Share on other sites More sharing options...
Flyinfool Posted March 17, 2015 Share #2 Posted March 17, 2015 Check the ground wires to the instrument panel. Link to comment Share on other sites More sharing options...
Husker88 Posted March 18, 2015 Author Share #3 Posted March 18, 2015 Check the ground wires to the instrument panel. I did, they're good. Clean and tight. The backlight works.....just not the gauges that show what gear I'm in, the fuel level and other things there... I'm frustrated as I know I found the "reset procedure" here before but I can't find that post. UGH!!!!! Link to comment Share on other sites More sharing options...
paysaw Posted March 18, 2015 Share #4 Posted March 18, 2015 Check the schematic for you bike.You could either have a broken ground or a power wire.Do both half's of the control LED not working? Link to comment Share on other sites More sharing options...
Husker88 Posted August 27, 2015 Author Share #5 Posted August 27, 2015 The whole LCD screen lights up but none of the "gauges" work... No fuel levels, gear position, nothing. Link to comment Share on other sites More sharing options...
MiCarl Posted August 27, 2015 Share #6 Posted August 27, 2015 The backlight isn't part of the LCD. One of the instrument cluster lamps shines through it via a light pipe. You could have bad connection(s), bad fuse(s) or a bad display. Link to comment Share on other sites More sharing options...
paysaw Posted August 27, 2015 Share #7 Posted August 27, 2015 Check schematic for ground and power wires using a multi meter.You could have a bad connector. Link to comment Share on other sites More sharing options...
