I have a 2008 RSV, I pulled up to a stop light one day when the light turned green I let out the clutch and the bike stalled out. When I looked down I had no power, I checked the main fuse and battery both were good. My neighbor looked on his phone while I was checking these, he said the ignition switch was notorious for going bad. I pulled the ignition switch cleaned it up, I put it back together and it worked fine. I rode for a week with no further problems, then getting ready to leave for work the same thing happened. I used a volt meter and checked the ignition switch sometimes it would make connection sometimes not, when I got the bike home I looked at the ignition switch again. I could get power and even got it to start a few times however I could never get the neutral light to come on. I put a universal switch on and get power to everything except I still do not get a neutral light and it will not turn over. I have checked the clutch switch, kick stand switch, neutral switch, automatic kill switch, manual kill switch, and the starter button. I suspect it is the ignition cut off relay or the ignitor, I have had no luck locating the ignition cut off relay and not sure if there is any way to test it if I did find it. Has anyone experiences this problem?
I have a random short in the radio, not sure if it is in the remote head or the main radio. I did find it shorting out so I disconnected the radio, after looking at a wiring diagram I noticed what looked like a wire going into the radio so I pulled the fuse and reconnected the radio. This does not seem to effect anything I have looked at.
It is the ignition switch. There is a write up in the tech sextion on how to by pass it with a toggle switch and I did this and ran mine that way for 2 years before I decided to tear the old one apart and rebuild/clean it up. It has lasted about 25,000 miles and is starting to give me problems again so will clean it up again this winter. Yu will have to join our little family to get the tech sections but it will be the best 12 bucks you ever spent
I make a ignition by-pass relay, just so the switch does not carry the entire load across it. I also can make a "keyless" by-pass set up if that is what you want. I have them for sale in the member vendor section (standard relay). Or drop me a PM for any questions. Its a plug and play outfit.
