DMW Posted July 28, 2014 Share #1 Posted July 28, 2014 2003 RSV, Having problem of bike not staying on track. Seems to run right, I correct runs left etc... Noticed front and rear tire scalloping, replaced tires this week, still same problem. Checked all wheel bearing. I have worn out 2 sets of E3 with no problem, till now. Can not recall hitting any bad holes in the road. Today I decided to try with no air in front forks, even 2.5lbs in both forks, when I let out air some oil came out. Could this be my problem? Link to comment Share on other sites More sharing options...
Peder_y2k Posted July 28, 2014 Share #2 Posted July 28, 2014 Might be steering head bearings getting loose. That's the usual cause of poor tracking -Pete, in Tacoma WA USA Link to comment Share on other sites More sharing options...
KICKSHOT Posted July 28, 2014 Share #3 Posted July 28, 2014 I would start by putting the bike on a jack and checking the steering head bearings for play, check the rear swing arm for play, basically check all bearings and suspension components for excessive wear or play. Including rear and front shocks. if you have to take the front wheel off and check shocks individually than do it. kickshot Link to comment Share on other sites More sharing options...
dacheedah Posted July 28, 2014 Share #4 Posted July 28, 2014 update? Link to comment Share on other sites More sharing options...
Venturous Randy Posted July 28, 2014 Share #5 Posted July 28, 2014 You may also have a problem with the head bearings being too tight. This is usually from the grease drying and making tight spots. RandyA Link to comment Share on other sites More sharing options...
cowpuc Posted July 28, 2014 Share #6 Posted July 28, 2014 Oil in air,,, unless you have added oil into the forks this almost sounds like your springs are sacked out. Might be time for progressives and an fork oil change.. Link to comment Share on other sites More sharing options...
Freebird Posted July 28, 2014 Share #7 Posted July 28, 2014 I agree with the steering head bearings being the problem. Could be too tight or they could be worn out. You didn't say how many miles on on the bike but Yamaha did a poor job greasing the bearings on some of these bikes. It has caused premature wear on the bearings. If you have over 50,000 miles on it and have never serviced/greased the bearings, they could be shot. Link to comment Share on other sites More sharing options...
Condor Posted July 28, 2014 Share #8 Posted July 28, 2014 (edited) The only reason for tires to start cupping is low tire pressure. I'd check and make sure you've got the pressure up to sidewall specs. Then if that doesn't cure your problem, like others have suggested, start looking at the steering head bearings.... Edited July 29, 2014 by Condor Link to comment Share on other sites More sharing options...
Venturous Randy Posted July 28, 2014 Share #9 Posted July 28, 2014 Worn out shocks on a car can cause tires to wear funny and I suspect the same thing can happen on a bike. You may need to confirm that you have an adequate amount of oil in your forks. RandyA Link to comment Share on other sites More sharing options...
DMW Posted July 29, 2014 Author Share #10 Posted July 29, 2014 Thanks to all I have 69,000 miles on bike, and head bearing were removed and relubed around 26,000. I have checked Head bearing and adjusted per process I found on here. Will be later this week to try inspecting shocks. I did do a short ride today with no air in front shocks, may have been a small change, but we are having some fairly gusty wind today, won,t judge till I can ride further. Any body else that has and idea, chime in please. Again Thanks to All, will post when I find it. Link to comment Share on other sites More sharing options...
