Hello Venture folks.
Looking for a software or web site that easy to create custom map routes, save to a Garmin GPS file format and the means to upload to my Zumo. What are others using? Recommendation?
S2
Steve:
I make routes all the time and actually really like the software that comes with the Garmin. One of the advantages is that as long as you keep the maps up to date then it won't have to recalculate the route when you import.. the software that I like is called Mapsource.
Wayne
Wayne
My ZUMO 665 did not have software with it, and now seem like Mapsource is not the software as Garmin site indicates BaseCamp.
Then if using MapQuest or other, needs the Garmin plugin "Garmin Communicator" which seems to be a bit of a challenge as it's not "plugin in" to my web browser.
Sorry to sound frustrated. At one time on older Microsoft softwares, it was easy, not, its not so easy.
Thanks
S2
Steve:
Wayne
I have been using the Honda Pwersports Trip Planner and it has worked well. Loading to the GPS is a bit tricky. You have to plug in the GPS so the software will know it's there but then it just puts a GPX file in your file downloads and you have to move it from there to your GPX files in the GPS unit.
Andy
I have been using Harley Davidson ride planner with garmin communicator on xp and win 7 ..does not work with android...easy to use ..set points as locations as waypoints doesn't go the way you want then change locations to waypoints..then save as..the n import to GPS..
I am very happy with a FREE program called TYRE. Trace your route everywhere. Much simpler to use than the basecamp or mapsource thing. Give it a try, what have you got to loose?
The Garmin software is Basecamp. BC replaced Mapsource a couple of years ago. The newer versions ('11+ IIRC) of Microsoft Streets and Trips will interact with the Zumo directly, although it is easier to interface with BC.
There are several tutorials on BC on www.zumoforums.com. Link here: http://garmin-mapsource.wikispaces.com/BaseCamp
S&T is much more intuitive. You can export a .gpx file and then import into BC. Further manipulation with BC is available, but you might want to just have it calculate a route and download it to your Zumo.
RR
Edited by RedRider
I'll second the vote for Tyre. It's far easier to use and read from the Garmin as well as write to it.
Dennis
