anzactm Posted May 19, 2014 Posted May 19, 2014 looking for the best spot to install a bad boy air horn on an 05.
Barrycuda Posted May 19, 2014 Posted May 19, 2014 See carbon one about the bracket and wiring. He can help you. Some put it on the right side, above or near the wiring and original horn.
Seaking Posted May 20, 2014 Posted May 20, 2014 looking for the best spot to install a bad boy air horn on an 05. I installed mine under the front fairing, left side of the radio. Back side of it wrapped in foam to prevent rattling and zip tied to the fairing frame.. The sound level is about 1 or 2 dbs less under the fairing than it hanging out in the breeze where rain and dirt can reduce its service life..
DarkHorse9825 Posted May 29, 2014 Posted May 29, 2014 The Carbon One bracket and relay work great I agree. Best set up for me since I like to try and do my own work, and I am not mechanically inclined.
djh3 Posted May 30, 2014 Posted May 30, 2014 I have mine on the left side by my foot. Up under the fairing. I had one mounted in the OEM horn location also but switched horns here a couple months ago.
bamico Posted June 3, 2014 Posted June 3, 2014 +1 for Carbon One. Larry's offering fit perfect. I've had mine installed for years with no issues. The Carbon One bracket and wiring harness make the installation a bolt on project. Bob
anzactm Posted June 4, 2014 Author Posted June 4, 2014 Thanks for all the replys, I ended up mounting it under the front fairing, nice and easy!
