stickhandle2 Posted May 11, 2014 Share #1 Posted May 11, 2014 (edited) Hi Folks, I decided today was the day I was going to pull the carbs on the 85 750 Virago our daughter rides, I had new carb boots for it as the old ones were cracking, and I also figured while the carbs were off I would give them a cleaning. Main reason for doing all this is the bike has been a little hard to start at times and figured with the weather being nice, today was as good a day as any. Long story not so short, I replaced the boots and cleaned the carbs and after re-installing them, the bike won't start, at least before it would always seem to want to start, but not now. I pulled the plugs and there is spark on both cylinders, there is fuel in the bowls, but when trying to start the bike it seems like it is starving for fuel. I have even pulled the carbs a second time to see if there was anything that I could see where I messed up but nothing at least to my untrained eyes. Any hints would be appreciated. Thanks, Mike. Edited May 11, 2014 by stickhandle2 spelling mistake Link to comment Share on other sites More sharing options...
Marcarl Posted May 11, 2014 Share #2 Posted May 11, 2014 Maybe best describe what exactly you did when you cleaned the crabs, did you take them apart, put in new gaskets and\or O-rings, did you clean and blow out the jets, or did you just clean them without taking them apart. Sorry for the questions, but cleaning carbs means many different things to many different people, and one method will give much different results than the other. Link to comment Share on other sites More sharing options...
stickhandle2 Posted May 11, 2014 Author Share #3 Posted May 11, 2014 Good point, the carbs were taken apart, diaphragm was removed, then the bowls were removed along with the floats, needle valve, main jet, main nozzle. I then cleaned these with carb cleaner by spraying them and all the holes in the carb, the loose valves and jets were also soaked in varsol. I then blew compressed air through the carb to further clean and also dry off all the parts. With there being 2 carbs I did one at a time so I wouldn't get any parts mixed up and had the manual with me in case I ran into a problem. Link to comment Share on other sites More sharing options...
Marcarl Posted May 11, 2014 Share #4 Posted May 11, 2014 Try putting a bit of gas into the throat of each carb and see if it will fire, or spray some carb cleaner down the throat while you're turning it over. If it fires then it's fuel related, if it still won't fire, re-check the ignition. Link to comment Share on other sites More sharing options...
stickhandle2 Posted May 11, 2014 Author Share #5 Posted May 11, 2014 Thanks Carl. Tried spraying some starter fluid in the carbs but nothing, it was getting spark but maybe not enough. I will look at the connections for the coils and stator if I can trace it. Thanks, Mike Link to comment Share on other sites More sharing options...
Black Owl Posted May 11, 2014 Share #6 Posted May 11, 2014 Not to be a SA, but did you check the kill switch? Flip it a couple of times as they have a tendency no stick so that even though the rocker switch looks like it is off, inside my be still grounding. Link to comment Share on other sites More sharing options...
mother Posted May 11, 2014 Share #7 Posted May 11, 2014 also have a virago my wife rides. it was getting really hard to start, looked like spark was okay. took carbs off cleaned put back on same problem. started with two new plugs, started first touch and runs like a charm again maybe worth a try cheers, Scott Link to comment Share on other sites More sharing options...
stickhandle2 Posted May 11, 2014 Author Share #8 Posted May 11, 2014 Not to be a SA, but did you check the kill switch? Flip it a couple of times as they have a tendency no stick so that even though the rocker switch looks like it is off, inside my be still grounding. Funny you say that, yes I did flipped it back and forth a few times also have a virago my wife rides. it was getting really hard to start, looked like spark was okay. took carbs off cleaned put back on same problem. started with two new plugs, started first touch and runs like a charm again maybe worth a try cheers, Scott / Scott Have also thought about doing that, earlier in the season when it was running like a dog, changed plugs and oil, it ran like a champ until a few days ago, when i decided it was time for a cleaning and swap out the old boots. Right now trying everything Mike Link to comment Share on other sites More sharing options...
hushpuppy Posted May 11, 2014 Share #9 Posted May 11, 2014 Fuel filter ? Link to comment Share on other sites More sharing options...
Neil86 Posted May 11, 2014 Share #10 Posted May 11, 2014 Mike.... long shot but even though its in neutral....try it with kickstand up in case something on the interlock circuit is trying to kill ignition. Link to comment Share on other sites More sharing options...
stickhandle2 Posted May 11, 2014 Author Share #11 Posted May 11, 2014 also have a virago my wife rides. it was getting really hard to start, looked like spark was okay. took carbs off cleaned put back on same problem. started with two new plugs, started first touch and runs like a charm again maybe worth a try cheers, Scott Well I didn't get new plugs but went and put an old set back in the bike....**&%$$$ thing started right up, let it run for a bit. Gonna put it back together and see what happens.....I give up. Mike. Link to comment Share on other sites More sharing options...
stickhandle2 Posted May 11, 2014 Author Share #12 Posted May 11, 2014 Mike.... long shot but even though its in neutral....try it with kickstand up in case something on the interlock circuit is trying to kill ignition. Hi Neil, I was thinking the same thing and actually did do that, but nothing.......then I grabbed the old set of plugs and of course it started. My brother called it a "what the ......" moment, I still don't really have a clue what the heck is going on. We will see how things are once everything is back on and hooked up. Mike Link to comment Share on other sites More sharing options...
