Bert2006 Posted May 4, 2014 Share #1 Posted May 4, 2014 After my last two rides I found that the left side bolt holding my pasing lamps on was working its way loose. I would simply re-tighten while being carefull so not to strip head. Well today afer a 6 hour run it completely worked itself out. For some reason it did not fall out but it was completely treaded out. Will be using blue lock-tight this time but I am amazed that it would keep working its way loose. This has never happenned before, but I did have to remove the lamps a few times this winter to do my LED conversion. Oh well, another thing to watch for. Link to comment Share on other sites More sharing options...
bongobobny Posted May 4, 2014 Share #2 Posted May 4, 2014 Be VERY careful with that loctite, even the fumes can eat plastic... Link to comment Share on other sites More sharing options...
wrnchjox Posted May 4, 2014 Share #3 Posted May 4, 2014 Poli-Grip will hold like loctite without being detrimental to your plastic parts. Link to comment Share on other sites More sharing options...
MidlifeVenture Posted May 4, 2014 Share #4 Posted May 4, 2014 A little silicone RTV also works well near plastic Link to comment Share on other sites More sharing options...
djh3 Posted May 5, 2014 Share #5 Posted May 5, 2014 Super glue can work also. RTV is a good bet though. If you want to do it up good drill some small holes in it and safety wire. Link to comment Share on other sites More sharing options...
