Jinksy4 Posted May 2, 2014 #1 Posted May 2, 2014 In a previous thread, I mentioned launching a valve shim from #3 inside exhaust bucket. My fear is that it made its way down the void under the cam gear since I can't find it anywhere else. Is it possible that the shim made its way to the bottom of the engine where I could retrieve it by dropping bottom engine cover? Any thoughts would be appreciated.
MiCarl Posted May 2, 2014 #2 Posted May 2, 2014 If it really dropped in there it probably made it clear to the bottom. I'd turn the engine over by hand a few times to make sure it wasn't hung up in something where it could do damage. If it made it to the bottom it could probably lie there forever without causing any issues. Some motorcycles have open spaces behind the clutch cover where you can get into the oil pan with a magnet. It's been awhile since I was into a Venture so I'm not sure if there is room to fish for a shim or not. Someone who has recently been into the clutch/shift segment might be able to give some input.
Peder_y2k Posted May 2, 2014 #3 Posted May 2, 2014 I'd try the magnet till I was blue in the face with frustration, but GET THAT THING OUT before operating the engine as oil flow could carry it into compromising places.!!!!!!! -Pete, in Tacoma WA USA
Jinksy4 Posted May 2, 2014 Author #4 Posted May 2, 2014 Thanks folks - I'm going to get a borescope and keep trying.
Jinksy4 Posted May 3, 2014 Author #6 Posted May 3, 2014 RedRider said: FYI - the HF boroscope works great. RR Picked one up today - $68 with discount coupon. Really works good. Tomorrow will see if it finds the elusive shim.
KICKSHOT Posted May 3, 2014 #7 Posted May 3, 2014 Not sure what king of magnet you may be using but I got one off the Matco Tool truck that is mounted on a flexible wire with handle and it will go almost any where. kickshot
Jinksy4 Posted May 3, 2014 Author #8 Posted May 3, 2014 KICKSHOT said: Not sure what king of magnet you may be using but I got one off the Matco Tool truck that is mounted on a flexible wire with handle and it will go almost any where. kickshot Thanks - if I find it is in the engine I will keep that in mind.
Jinksy4 Posted May 3, 2014 Author #9 Posted May 3, 2014 Jinksy4 said: In a previous thread, I mentioned launching a valve shim from #3 inside exhaust bucket. My fear is that it made its way down the void under the cam gear since I can't find it anywhere else. Is it possible that the shim made its way to the bottom of the engine where I could retrieve it by dropping bottom engine cover? Any thoughts would be appreciated. Thanks folks for the help. I found it down by the radiator held vertically by its oil film - no way to see it without bore scope. What a relief!! Ready to put it back together and ride - as soon as the rain stops. Thanks again!
Peder_y2k Posted May 3, 2014 #10 Posted May 3, 2014 Like I said in another post, one's first impression is usually correct, and indeed the shim did what you thought.........it headed to the floor, but didn't quite make it. -Pete, in Tacoma WA USA
Flyinfool Posted May 3, 2014 #11 Posted May 3, 2014 Glad you found it and the shim eating gremlins did not get it. AND you got a cool new tool to boot.
