bill4you502 Posted March 30, 2014 Posted March 30, 2014 Anyone know of any "Bright White" seal beam bulbs that will fit the OEM passing light buckets on a '06 RSV???? "May the wind be at your back and the sun in your face!!!"
garyw Posted March 30, 2014 Posted March 30, 2014 I just put in a set of 50W halogen sealed beams in my 2008 RSV. I would think they would fit yours as well. Very bright compared to the factory 35W regular blubs. http://www.bulbamerica.com/ge-50w-h7606-par36-screw-terminals-tractor-bulb.html
djh3 Posted March 31, 2014 Posted March 31, 2014 If you are running 50w lights in the passing light bar you need to be running it thru a relay and off a dedicated power wire. If you are running it thru the OEM wiring harness you are asking for trouble. The fuse was still working, but you can see what was going to happen right?
djh3 Posted March 31, 2014 Posted March 31, 2014 Yes, but par 36 bulbs come in 35w & 55w. Mine had 35w bulbs in it and not set up on a relay and you can see what kind of strain on system. I leave mine on all the time.
bill4you502 Posted April 3, 2014 Author Posted April 3, 2014 Thanks to all for the responses. Is there an easy way to install a relay and dedicated power line? Is there an alternative to par 36, 55 wt bulbs? I would just like something "whiter" to match the Sylvania Bright White headlight H4 bulb I put in........Thanks again to y'all from Kentucky! GO CATS!!!!!!
Bert2006 Posted April 3, 2014 Posted April 3, 2014 Check this out: http://www.venturerider.org/forum/showthread.php?t=84450
djh3 Posted April 4, 2014 Posted April 4, 2014 I would have to go out and find my old 35w bulbs, but part of the reason I changed them was even without the HID they looked sort of yellow. I am told that PIAA has a holgen H3 bulb that looks pretty close to the LED or HID a nice crisp white.
